简介
This guide will show you how to replace the battery of your Motorola Moto G 3rd Generation. Replacing this part requires disassembling much of the phone.
If your battery is swollen, take appropriate precautions.
你所需要的
Use your fingernail to pry under the notch on the bottom of the phone and remove the back cover.
Remove the ten 2.4 mm T4 screws from the sides of the motherboard.
Remove the four 4.5 mm T4 screws from the top and bottom of the motherboard.
Use a spudger to carefully pull the battery wire connector out from under the bridge.
40等其他人完成本指南。
23条评论
Thanks a lot, it has been very useful! .. Unfortunately my device is still not working ...
No audio sound and ring tone is not working of my Moto G3 set. pl help me what can i do
J. Sarkar
Same here, did you solve it?
Lost all sounds on mine too. But the battery replacement went very smooth.
I've extracted the battery and am awaiting a replacement. It holds a charge OK but has bulged to 10mm thick plus some gaseous inflation. This caused the motherboard to bulge in response and popped the screen out of the housing. I suspect that it was, before the "pop" made it obvous, the cause of the failure of the torch/flash. This is because the connection is just by contact pressure between back and motherboard and in the rough centre of the device where the bulge pressure would be most noticeable. So I am hoping for a double cure...
