跳转到主内容
Motorola Moto G 1st Generation Speaker Replacement
你所需要的
  1. 注意:步骤 1-3 源自标记为进行中的 指南
    Motorola Moto G 1st Generation Speaker Replacement, Rear Panel: 步骤 1 中的图像 1,3 Motorola Moto G 1st Generation Speaker Replacement, Rear Panel: 步骤 1 中的图像 2,3 Motorola Moto G 1st Generation Speaker Replacement, Rear Panel: 步骤 1 中的图像 3,3
    • Before you start following any of the steps of this guide, completely turn the device off.
    • Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
  2. Motorola Moto G 1st Generation Speaker Replacement, Removing the Screws: 步骤 2 中的图像 1,1
    • Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
  3. Motorola Moto G 1st Generation Speaker Replacement, Removing the Battery Cover: 步骤 3 中的图像 1,2 Motorola Moto G 1st Generation Speaker Replacement, Removing the Battery Cover: 步骤 3 中的图像 2,2
    • Use a plastic opening tool to remove the protective cover.
    • Carefully work the plastic tool around all the edges of the phone.
    • The protective cover holds the Volume and the Home buttons which might fall off the assembly when the cover is removed.
  4. Motorola Moto G 1st Generation Speaker Replacement, Removing the Speaker: 步骤 4 中的图像 1,3 Motorola Moto G 1st Generation Speaker Replacement, Removing the Speaker: 步骤 4 中的图像 2,3 Motorola Moto G 1st Generation Speaker Replacement, Removing the Speaker: 步骤 4 中的图像 3,3
    • Use the plastic opening tool to remove the Speaker from the protective cover.
结论
2等其他人完成本指南。
Radostin Lobodov
于10/16/14注册
2,904 声望
创作了6篇指南
团队
UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S5G7
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,164
