简介
This guide shows you how to replace the speaker on a Motorola Moto G 1st Generation smartphone.
你所需要的
步骤 1 Rear Panel
注意:步骤 1-3 源自标记为进行中的 指南。
Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
Use the plastic opening tool to remove the Speaker from the protective cover.
2等其他人完成本指南。
