简介
The buttons on the Moto G can sometimes get lost or misaligned. This guide will show you how to replace them or fix them.
你所需要的
You can remove the outer cover on the back of the phone by using a plastic opening tool. After removal the inner back cover will be exposed as shown.
This part is moderately difficult, especially if you've never taken the outer back cover off before this point.
It may take you several tries, but please be patient. The cover is surprisingly flexible, but not enough to withstand a lot of pressure.
Shut down the phone.
Push SIM card until it pops out.
Remove SIM card.
Be careful as to not damage the microSD memory card. Unlike the SIM card, pushing this in may not spring release, as there may not be an eject mechanism.
If there is no spring release eject mechanism, hopefully your microSD card has a ridge/raised edge that you can push on with your fingernail or plastic/rubber tool to push the card out. This may be difficult - be patient and do not use excessive force/sharp tools that could cause permanent damage and permanent loss of data.
Using a T5 Torx screwdriver head, take out the 14 screws (3.5 mm diameter and 5 mm long) that hold the back plate in place.
Make sure to keep all of the screws together, as they are very easily lost.
The magnetic project mat or a container is a great way to keep all the little metal screws as well as other small metal pieces from being lost.
Die Schrauben sind Torx T4!
I used T5 and it worked, but it was a very tight fit. I guess tight fit is better for the screws than loose fit, but still, consider trying a T4 screwdriver.
Use the plastic opening tool to take out the inner back cover after all the screws have been removed.
This will expose the motherboard and the attached battery.
Take note that once the inner back cover is removed the volume and power buttons on the side can easily fall out or be removed.
The buttons are extremely easy to replace and may fall out when opening the phone.
They are located on the left side when the front plate is facing down.
Use a tool or your fingers to gently lift the button out of its socket.
To replace, line the new button up in the socket and press down.
The buttons are not secured in anyway, so securing the back inner cover before turning the device over or jostling the device is a good idea. This will ensure buttons stay in place.
13等其他人完成本指南。
8条评论
Step 4 "We highlighted buttons with pink circles for easy recognition." except that there's no pink circles. ummm?
Changes have been made since my group finished this project by others not associated with the group. I'm assuming an ifixit editor is trying to stay busy making necessary and unnecessary changes. Not sure why they removed highlighting circles.
Casey J.
sir my buttons are working but the hardware keys (inside the power & volume keys attached with board) are not working please tell me how to fix it..
To really repair the moto G first Gen's power buton you need to do micro Soldering. It is soldering to the motherborad.
If you change the little piece of plastic like in the tutorial it will not repair de power button if it is broken. this piece only press on a button inside (like the little thing with the 3 red x one the last step) and this buton send signal to the motherboard.
i don’t have the skills to do microsoldering, so i used jb plasticweld around the tactile switch to hold it in place (switch worked fine when it was held down to the mb). we’ll see how long it holds!
