跳转到主内容
Motorola Moto E6 Speaker Replacement
你所需要的
  1. Motorola Moto E6 Speaker Replacement, Back Cover: 步骤 1 中的图像 1,2 Motorola Moto E6 Speaker Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Speaker Replacement, Battery: 步骤 2 中的图像 1,1
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Speaker Replacement, Speaker: 步骤 3 中的图像 1,1
    • Remove the eleven 3.8 mm T4 Torx screws located above the battery compartment.
  4. Motorola Moto E6 Speaker Replacement: 步骤 4 中的图像 1,1
    • Use the plastic opening tools to pry open the piece located at the top of the device.
    • Start by prying open the side of the compartment and work your way towards the camera module, prying open the compartment as you go.
    • Pop off the piece above the battery compartment.
  5. Motorola Moto E6 Speaker Replacement: 步骤 5 中的图像 1,3 Motorola Moto E6 Speaker Replacement: 步骤 5 中的图像 2,3 Motorola Moto E6 Speaker Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using tweezers, lift the speaker from the motherboard located at the top of the device.
    • When replacing with a new component, make sure the clips are facing towards the user.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 1,176
