简介
This guide will show the user how to replace the screen assembly in the Motorola Moto E6. It should be replaced if it is malfunctioning or broken. A cracked screen is prone to further damage and should be fixed promptly. A cracked screen can also be potentially hazardous and the user should be cautious while replacing.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
你所需要的
Begin by prying open the bottom right of the device using the plastic opening tool.
Work your way around the edge of the device, slowly prying open the casing until it pops off.
Remove the seven 3.8 mm T4 screws on the piece located below the battery compartment.
After removing the motherboard and the charging dock, the screen assembly can be replaced.
3等其他人完成本指南。
4条评论
Pro Tip.
The OEM parts for this do not include the flex that connects the Sub to main PBA, nor the earspeaker, nor the buttons or Vibration motor, so all of those will need to be moved over if you are utilizing OEM original components.
you get me right to the point where i can get to the screen. now, how i do iget it off? put the new one on???
Use heat on the display to loosen the adhesive. Then you can separate the display and put in the new one.
