跳转到主内容
Motorola Moto E6 Rear Facing Camera Replacement
你所需要的
  1. Motorola Moto E6 Rear Facing Camera Replacement, Back Cover: 步骤 1 中的图像 1,2 Motorola Moto E6 Rear Facing Camera Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Rear Facing Camera Replacement, Battery: 步骤 2 中的图像 1,1
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Rear Facing Camera Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Remove the eleven 3.8 mm T4 Torx screws located above the battery compartment.
  4. Motorola Moto E6 Rear Facing Camera Replacement: 步骤 4 中的图像 1,1
    • Use the plastic opening tools to pry open the piece located at the top of the device.
    • Start by prying open the side of the compartment and work your way towards the camera module, prying open the compartment as you go.
    • Pop off the piece above the battery compartment.
  5. Motorola Moto E6 Rear Facing Camera Replacement: 步骤 5 中的图像 1,1
    • Remove the two 1.1 mm T4 Torx screws from the bottom left and top right sides of the motherboard.
  6. Motorola Moto E6 Rear Facing Camera Replacement: 步骤 6 中的图像 1,1
    • Remove the two press fit cables at the bottom of the motherboard with the plastic opening tool.
    • Remove the coaxial cable using the plastic opening tool.
    • After removing the cables, remove the motherboard from the phone by hand.
  7. Motorola Moto E6 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 7 中的图像 1,1
    • Remove the press fit cable using the plastic opening tool, and remove the camera from the phone.
结论
团队
Cal Poly, Team S2-G3, White Winter 2020 Cal Poly, Team S2-G3, White Winter 2020 的会员
CPSU-WHITE-W20S2G3
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 596
