跳转到主内容
Motorola Moto E6 Charging Dock Replacement
你所需要的
  1. Motorola Moto E6 Charging Dock Replacement, Back Cover: 步骤 1 中的图像 1,2 Motorola Moto E6 Charging Dock Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Charging Dock Replacement, Battery: 步骤 2 中的图像 1,1
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Charging Dock Replacement, Charging Dock: 步骤 3 中的图像 1,1
    • Remove the seven 3.8 mm T4 screws on the piece located below the battery compartment.
  4. Motorola Moto E6 Charging Dock Replacement: 步骤 4 中的图像 1,1
    • Begin prying off the bottom piece with the opening tools on the divot located at the bottom left.
    • Work your way around the piece until it pops off.
  5. Motorola Moto E6 Charging Dock Replacement: 步骤 5 中的图像 1,1
    • Remove the press fit cable at the top of the charging dock with the plastic opening tool.
    • Remove the coaxial cable using the plastic opening tool.
  6. Motorola Moto E6 Charging Dock Replacement: 步骤 6 中的图像 1,1
    • Remove the two 1.1 mm T4 Torx screws on the bottom right and top left sides of the charging dock.
    • Remove the charging dock by hand.
结论
6等其他人完成本指南。
Matthew Zelten
于01/23/20注册
471 声望
创作了3篇指南
团队
Cal Poly, Team S2-G3, White Winter 2020 Cal Poly, Team S2-G3, White Winter 2020 的会员
CPSU-WHITE-W20S2G3
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 40
总计 2,882
