跳转到主内容
Motorola Moto E4 Rear Facing Camera Replacement
你所需要的
  1. Motorola Moto E4 Rear Facing Camera Replacement, Remove the rear cover: 步骤 1 中的图像 1,2 Motorola Moto E4 Rear Facing Camera Replacement, Remove the rear cover: 步骤 1 中的图像 2,2
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Rear Facing Camera Replacement, Remove the motherboard cover: 步骤 2 中的图像 1,2 Motorola Moto E4 Rear Facing Camera Replacement, Remove the motherboard cover: 步骤 2 中的图像 2,2
    • The battery is shown inserted in the Moto E4, but it should be removed before performing the following step.
    • Remove all nine 4 mm Phillips screws from the top plastic cover.
  3. Motorola Moto E4 Rear Facing Camera Replacement: 步骤 3 中的图像 1,2 Motorola Moto E4 Rear Facing Camera Replacement: 步骤 3 中的图像 2,2
    • Gently pry up the plastic cover using a plastic opening tool.
    • Start by inserting the tool under the cover's right edge, as indicated by the first picture.
    • Pry up, and continue prying around the rest of the cover in a counter clockwise path.
    • Once loose, remove the plastic cover from the phone.
  4. Motorola Moto E4 Rear Facing Camera Replacement: 步骤 4 中的图像 1,3 Motorola Moto E4 Rear Facing Camera Replacement: 步骤 4 中的图像 2,3 Motorola Moto E4 Rear Facing Camera Replacement: 步骤 4 中的图像 3,3
    • This step can be skipped if you are only removing the front-facing camera. For all other repairs, continue as follows.
    • Disconnect the rear-facing camera by prying straight up on the connector on its right side.
    • Remove the rear-facing camera from the Moto E4.
结论
Nate Tjepkema
于01/24/19注册
1,236 声望
创作了7篇指南
团队
Cal Poly, Team S2-G4, White Winter 2019 Cal Poly, Team S2-G4, White Winter 2019 的会员
CPSU-WHITE-W19S2G4
4 名成员
创作了22篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 713
