跳转到主内容
Motorola Moto E4 Plus Motherboard Replacement
你所需要的
  1. Motorola Moto E4 Plus Motherboard Replacement, Remove the back cover: 步骤 1 中的图像 1,3 Motorola Moto E4 Plus Motherboard Replacement, Remove the back cover: 步骤 1 中的图像 2,3 Motorola Moto E4 Plus Motherboard Replacement, Remove the back cover: 步骤 1 中的图像 3,3
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Motherboard Replacement: 步骤 2 中的图像 1,2 Motorola Moto E4 Plus Motherboard Replacement: 步骤 2 中的图像 2,2
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Motherboard Replacement, Remove the midframe screws: 步骤 3 中的图像 1,1
    • Remove the nineteen 3.2 mm long T3 screws securing the plastic midframe.
  4. Motorola Moto E4 Plus Motherboard Replacement, Release the midframe clips: 步骤 4 中的图像 1,2 Motorola Moto E4 Plus Motherboard Replacement, Release the midframe clips: 步骤 4 中的图像 2,2
    • The plastic midframe is still held in place with clips.
    • Insert the flat end of a spudger into the midframe seam at the bottom left corner of the phone (near the microphone hole).
    • Twist the spudger to release the plastic clip.
    • Repeat the process for the clip near the top right corner of the phone.
  5. Motorola Moto E4 Plus Motherboard Replacement, Remove the midframe: 步骤 5 中的图像 1,2 Motorola Moto E4 Plus Motherboard Replacement, Remove the midframe: 步骤 5 中的图像 2,2
    • Lift the bottom edge of the plastic midframe upwards until the clips along the top edge release.
    • Remove the plastic midframe.
    • To reattach the plastic midframe, line up the midframe to the phone and squeeze along the edges to engage the clips.
  6. Motorola Moto E4 Plus Motherboard Replacement, Disconnect the battery: 步骤 6 中的图像 1,2 Motorola Moto E4 Plus Motherboard Replacement, Disconnect the battery: 步骤 6 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
  7. Motorola Moto E4 Plus Motherboard Replacement, Disconnect the display cable: 步骤 7 中的图像 1,2 Motorola Moto E4 Plus Motherboard Replacement, Disconnect the display cable: 步骤 7 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the display cable from its motherboard socket, near the bottom left corner of the motherboard.
  8. Motorola Moto E4 Plus Motherboard Replacement, Disconnect the antenna cable: 步骤 8 中的图像 1,2 Motorola Moto E4 Plus Motherboard Replacement, Disconnect the antenna cable: 步骤 8 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the antenna cable from its motherboard socket.
  9. Motorola Moto E4 Plus Motherboard Replacement, Disconnect the interconnect cable: 步骤 9 中的图像 1,2 Motorola Moto E4 Plus Motherboard Replacement, Disconnect the interconnect cable: 步骤 9 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the interconnect cable from its motherboard socket.
  10. Motorola Moto E4 Plus Motherboard Replacement, Remove the motherboard screws: 步骤 10 中的图像 1,1
    • Remove the two black 3.2 mm long T3 screws securing the motherboard.
  11. Motorola Moto E4 Plus Motherboard Replacement, Remove the motherboard: 步骤 11 中的图像 1,2 Motorola Moto E4 Plus Motherboard Replacement, Remove the motherboard: 步骤 11 中的图像 2,2
    • Grasp the motherboard by the top corners and lift it out of the phone.
    • Remove the motherboard.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Moto E4 Plus Answers community for help.
3等其他人完成本指南。
Arthur Shi
于01/03/18注册
248,445 声望
创作了503篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了16,573篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 1,545
