跳转到主内容
Motorola Moto E4 Motherboard Cover Replacement
你所需要的
  1. Motorola Moto E4 Motherboard Cover Replacement, Remove the rear cover: 步骤 1 中的图像 1,2 Motorola Moto E4 Motherboard Cover Replacement, Remove the rear cover: 步骤 1 中的图像 2,2
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Motherboard Cover Replacement, Motherboard Cover: 步骤 2 中的图像 1,2 Motorola Moto E4 Motherboard Cover Replacement, Motherboard Cover: 步骤 2 中的图像 2,2
    • Remove all nine 4mm screws from the top plastic cover with a Phillips driver.
  3. Motorola Moto E4 Motherboard Cover Replacement: 步骤 3 中的图像 1,2 Motorola Moto E4 Motherboard Cover Replacement: 步骤 3 中的图像 2,2
    • Gently pry up the plastic cover from the gap between it and the phone edge.
    • Start on the right side as indicated by the first picture.
    • Continue prying around the rest of the cover in a counter clockwise path.
    • Once loose, remove the plastic cover from the phone.
结论
2等其他人完成本指南。
Nate Tjepkema
于01/24/19注册
1,236 声望
创作了7篇指南
团队
Cal Poly, Team S2-G4, White Winter 2019 Cal Poly, Team S2-G4, White Winter 2019 的会员
CPSU-WHITE-W19S2G4
4 名成员
创作了22篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 605
