跳转到主内容
Motorola Moto E4 Front Facing Camera Replacement
你所需要的
  1. Motorola Moto E4 Front Facing Camera Replacement, Remove the rear cover: 步骤 1 中的图像 1,2 Motorola Moto E4 Front Facing Camera Replacement, Remove the rear cover: 步骤 1 中的图像 2,2
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Front Facing Camera Replacement, Motherboard Cover: 步骤 2 中的图像 1,2 Motorola Moto E4 Front Facing Camera Replacement, Motherboard Cover: 步骤 2 中的图像 2,2
    • Remove all nine 4mm screws from the top plastic cover with a Phillips driver.
  3. Motorola Moto E4 Front Facing Camera Replacement: 步骤 3 中的图像 1,2 Motorola Moto E4 Front Facing Camera Replacement: 步骤 3 中的图像 2,2
    • Gently pry up the plastic cover from the gap between it and the phone edge.
    • Start on the right side as indicated by the first picture.
    • Continue prying around the rest of the cover in a counter clockwise path.
    • Once loose, remove the plastic cover from the phone.
  4. Motorola Moto E4 Front Facing Camera Replacement, Front Facing Camera: 步骤 4 中的图像 1,2 Motorola Moto E4 Front Facing Camera Replacement, Front Facing Camera: 步骤 4 中的图像 2,2
    • Detach the front facing cable ribbon connector using an iFixit opening tool and lift the camera out of position.
    • To completely remove the front facing camera from the phone, the copper colored adhesive must be torn. The camera will still with the adhesive removed, but there may be unknown side effects.
结论
2等其他人完成本指南。
Nate Tjepkema
于01/24/19注册
1,236 声望
创作了7篇指南
团队
Cal Poly, Team S2-G4, White Winter 2019 Cal Poly, Team S2-G4, White Winter 2019 的会员
CPSU-WHITE-W19S2G4
4 名成员
创作了22篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 469
