跳转到主内容
Motorola Moto 360 Rear Cover Replacement
你所需要的
  1. Motorola Moto 360 Rear Cover Replacement, Rear Cover: 步骤 1 中的图像 1,1
    • Set the watch face down on a flat surface.
    • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
  2. Motorola Moto 360 Rear Cover Replacement: 步骤 3 中的图像 1,2 Motorola Moto 360 Rear Cover Replacement: 步骤 3 中的图像 2,2
    • Gently slide the blue opening pick between the rear cover and the metal casing.
    • The rear cover is extremely fragile. Be very delicate when using the opening pick.
    • Work your way entirely around the rear cover.
    • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
  3. Motorola Moto 360 Rear Cover Replacement: 步骤 4 中的图像 1,1
    • Once the adhesive has been successfully loosened, gently pull the rear cover off.
结论
9等其他人完成本指南。
Cole Twitchell
于01/30/15注册
1,688 声望
创作了2篇指南
团队
Cal Poly, Team 17-32, Amido Winter 2015 Cal Poly, Team 17-32, Amido Winter 2015 的会员
CPSU-AMIDO-W15S17G32
4 名成员
创作了18篇指南
一条评论
How does this *rear cover replacement* count as "no parts required"?
Kyle Mitchell - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 12,799
