跳转到主内容
Motorola Moto 360 Case Locking Fastener Replacement
你所需要的
  1. Motorola Moto 360 Case Locking Fastener Replacement, Wrist Strap: 步骤 1 中的图像 1,1
    • Locate the spring-loaded pin that attaches the wrist strap to the watch.
    • There is a tiny groove on the end of the pin. This is where you will place the tweezers.
  2. Motorola Moto 360 Case Locking Fastener Replacement: 步骤 2 中的图像 1,1
    • Take care not to lose the spring-loaded pin when removing the strap.
    • Use the tweezers to compress the spring-loaded pin so the strap can be removed.
  3. Motorola Moto 360 Case Locking Fastener Replacement: 步骤 3 中的图像 1,2 Motorola Moto 360 Case Locking Fastener Replacement: 步骤 3 中的图像 2,2
    • Pull the wristband away from the watch face.
  4. Motorola Moto 360 Case Locking Fastener Replacement, Case Locking Fasteners: 步骤 4 中的图像 1,1
    • Locate the rectangular end of the fastener inside the wrist strap mounting pocket.
  5. Motorola Moto 360 Case Locking Fastener Replacement: 步骤 5 中的图像 1,2 Motorola Moto 360 Case Locking Fastener Replacement: 步骤 5 中的图像 2,2
    • Push the point of the pin in behind the fastener and pry it out. There is a notch near the end of the fastener which will engage the pin. Once the end pops out, the fastener will slide out of the slot easliy. Repeat to remove all four of them.
    • That's it. Now the two halves of the watch can be easily separated by just pulling gently with your fingers.
结论
18等其他人完成本指南。
Chris K.
于02/27/17注册
661 声望
撰写一个指南
9条评论
I lost my fasteners... where can I buy more?
thiagopimenta - 回复
One misleading thing about this guide: pictures show the back cover taken off, while in fact you don't need to do this -- just take out the fasteners.
Дмитрий Трубин (Dmitry Trubin) - 回复
Absolutely correct, you don't need to heat or take the back off. I will say though that getting those clips out was damnably fiddly for me.
Ethan Duffy -
ou peut acheter Case Locking Fastener Replacement pour moto360 mon bracelet tien pas
svp chez besoin case locking fastener
abellegarde - 回复
don't remove the back!
follow this video for removing the locking pins.
I did it, so can you!
https://www.youtube.com/watch?v=Jw3n5qbG...
davidlanchart - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 23
总计 7,527
