跳转到主内容
简介
The Motorola Moto 360 2nd gen is a very delicate device, so take extreme caution when breaking the device apart. Use this guide to replace the LCD Display in your device.
  1. Use your finger or the tip of a spudger to compress the pin securing the watch band. With the pin compressed, remove the watch band. With the pin compressed, remove the watch band.
    • Use your finger or the tip of a spudger to compress the pin securing the watch band.
    • With the pin compressed, remove the watch band.
  2. Insert an opening tool to into the small notch next to the microphone hole. Slide the opening tool around the perimeter of the trim ring while prying up slightly to slice through the adhesive securing the ring to the watch. If the trim ring does not readily separate from the watch, heat it with an iOpener or hair dryer to soften the adhesive.
    • Insert an opening tool to into the small notch next to the microphone hole.
    • Slide the opening tool around the perimeter of the trim ring while prying up slightly to slice through the adhesive securing the ring to the watch.
    • If the trim ring does not readily separate from the watch, heat it with an iOpener or hair dryer to soften the adhesive.
    • Remove the trim ring.
  3. Use an opening tool to slowly pry the button trim ring straight up. If you bend or rotate the trim ring while removing it, you may damage the small pins that secure it. Remove the trim ring.
    • Use an opening tool to slowly pry the button trim ring straight up.
    • If you bend or rotate the trim ring while removing it, you may damage the small pins that secure it.
  4. Use a small pin spanner to unscrew the button. If you don't have access to the proper spanner, you can use a pair of tweezers, a very small screwdriver, or a paperclip to unscrew the button assembly. Insert your chosen tool into one of the grooves around the button and push sideways.
    • Use a small pin spanner to unscrew the button.
    • If you don't have access to the proper spanner, you can use a pair of tweezers, a very small screwdriver, or a paperclip to unscrew the button assembly. Insert your chosen tool into one of the grooves around the button and push sideways.
    • There is blue thread locker on these threads, so light heat on the button may help to soften the thread locker.
    • Remove the button.
    • There is a small red o-ring that may fall off the button threads when the button is removed. Make sure not to lose the o-ring.
  5. While holding the outer case steady, twist the inner watch assembly clockwise until it stops. While holding the outer case steady, twist the inner watch assembly clockwise until it stops.
    • While holding the outer case steady, twist the inner watch assembly clockwise until it stops.
  6. Hold the outer watch case steady and push against the bottom of the inner assembly to remove the inner assembly from the frame. It should not take much force to push the inner assembly out of the watch frame. If it seems stuck, make sure that you've rotated the inner assembly far enough to release it from the frame. It should not take much force to push the inner assembly out of the watch frame. If it seems stuck, make sure that you've rotated the inner assembly far enough to release it from the frame.
    • Hold the outer watch case steady and push against the bottom of the inner assembly to remove the inner assembly from the frame.
    • It should not take much force to push the inner assembly out of the watch frame. If it seems stuck, make sure that you've rotated the inner assembly far enough to release it from the frame.
  7. Use a fingernail or opening tool to pry the plastic lower assembly away from the display assembly. Do not completely separate the lower assembly from the display assembly yet. There is a cable connecting the two that must be disconnected first. Do not completely separate the lower assembly from the display assembly yet. There is a cable connecting the two that must be disconnected first.
    • Use a fingernail or opening tool to pry the plastic lower assembly away from the display assembly.
    • Do not completely separate the lower assembly from the display assembly yet. There is a cable connecting the two that must be disconnected first.
  8. Use tweezers to remove the small rubber strip between the battery and the display ZIF connector.
    • Use tweezers to remove the small rubber strip between the battery and the display ZIF connector.
  9. Use a spudger to lift the locking flap on  the display ZIF connector. Use a spudger to lift the locking flap on  the display ZIF connector.
    • Use a spudger to lift the locking flap on the display ZIF connector.
  10. Lift the display cable straight out of its connector on the motherboard. Lift the display cable straight out of its connector on the motherboard.
    • Lift the display cable straight out of its connector on the motherboard.
  11. After successfully loosening the adhesive on the back of the display, slide the display out the casing.
    • After successfully loosening the adhesive on the back of the display, slide the display out the casing.
结论
7等其他人完成本指南。
Ivana Lum Wai
于2017年08月22日注册
263 信誉积分
撰写一个指南
团队
USF Tampa, Team S6-G1, Remmell Fall 2017 USF Tampa, Team S6-G1, Remmell Fall 2017 的会员
USFT-REMMELL-F17S6G1
4 名成员
创作了19篇指南
3条评论
Where can I buy the screen for the 2-nd generation Moto360 watch ?
Kevin - 回复
Its far easier to remove watch from body by unscrewing the crown, remove the bottom ring then heat the bezel a little so that you can turn the bezel about 10mm counter clockwise with a razor blade edge, then push the whole body of the watch through the metal casing and it should come out easily through the top of the watch in one piece making it easier to access the pcb without damaging anything
Bernard McGrath - 回复
There is only one correct way to disassemble the watch. That is to unscrew the crown as mentioned in previous comment and another guide for 360 Gen 2.
This guide here should be either revised or taken down.
It leads to broken watch if you tried to follow. I was lucky to step out from step 5 and followed the other guide instead…
vincent0wang - 回复
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 10
过去的30天: 38
总计 6,148
