跳转到主内容
Motorola MOTO W755 Cell Phone Functional Keypad Replacement
你所需要的
  1. Motorola MOTO W755 Cell Phone Functional Keypad Replacement, Main Logic Board: 步骤 1 中的图像 1,1
    • Using the T5 Torx-screwdriver, remove the four 5.5 mm screws on the back panel.
  2. Motorola MOTO W755 Cell Phone Functional Keypad Replacement: 步骤 2 中的图像 1,2 Motorola MOTO W755 Cell Phone Functional Keypad Replacement: 步骤 2 中的图像 2,2
    • Using a plastic opening tool, carefully peel back the rubber strip located at the bottom of the keypad
    • Remove the two T5 Torx-screws underneath the rubber strip using the T5 Torx-screwdriver
  3. Motorola MOTO W755 Cell Phone Functional Keypad Replacement: 步骤 3 中的图像 1,3 Motorola MOTO W755 Cell Phone Functional Keypad Replacement: 步骤 3 中的图像 2,3 Motorola MOTO W755 Cell Phone Functional Keypad Replacement: 步骤 3 中的图像 3,3
    • Using the flat end of the plastic opening tool, insert it in the gap between the charging port and plastic at the bottom left side of the phone.
    • Slide the opening tool around the phone clockwise until you reach the audio port.
    • Twist the opening tool until the plastic pops off from the body of the phone. This make require a small amount of force.
  4. Motorola MOTO W755 Cell Phone Functional Keypad Replacement: 步骤 4 中的图像 1,1
    • Remove the plastic covering completely from the body of the phone.
  5. Motorola MOTO W755 Cell Phone Functional Keypad Replacement: 步骤 5 中的图像 1,2 Motorola MOTO W755 Cell Phone Functional Keypad Replacement: 步骤 5 中的图像 2,2
    • Using the plastic opening tool, carefully unclip the cable ribbon from the main logic board. Be sure not to tear it because the flex is very fragile.
    • Remove the main logic board.
  6. Motorola MOTO W755 Cell Phone Functional Keypad Replacement, Functional Keypad: 步骤 6 中的图像 1,1
    • Lift the plastic cover of the keypad from the top of the main logic board and peel it off.
结论
Roberta Glenn
于07/11/12注册
43 声望
创作了4篇指南
团队
Cal Poly, Team 1-3, Regan SU 2012 Cal Poly, Team 1-3, Regan SU 2012 的会员
CPSU-REGAN-SU12S1G3
2 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,966
