跳转到主内容
Motorola MOTO W755 Cell Phone Camera Replacement
你所需要的
  1. Motorola MOTO W755 Cell Phone Camera Replacement, Battery: 步骤 1 中的图像 1,2 Motorola MOTO W755 Cell Phone Camera Replacement, Battery: 步骤 1 中的图像 2,2
    • Using your finger, press down on the clip holding the back cover on
    • Pull the back cover off.
  2. Motorola MOTO W755 Cell Phone Camera Replacement: 步骤 2 中的图像 1,2 Motorola MOTO W755 Cell Phone Camera Replacement: 步骤 2 中的图像 2,2
    • Place thumb and index finger in the spaces on either side of the battery.
    • Pull battery out.
  3. Motorola MOTO W755 Cell Phone Camera Replacement, Top Panel: 步骤 3 中的图像 1,3 Motorola MOTO W755 Cell Phone Camera Replacement, Top Panel: 步骤 3 中的图像 2,3 Motorola MOTO W755 Cell Phone Camera Replacement, Top Panel: 步骤 3 中的图像 3,3
    • Use the plastic opening tool to pull peel back screen cover.
    • Gently peel back the screen cover from the speaker slit.
    • Using the T6 Torx-screwdriver, remove the four 4.3 mm screws from the top panel.
  4. Motorola MOTO W755 Cell Phone Camera Replacement: 步骤 4 中的图像 1,3 Motorola MOTO W755 Cell Phone Camera Replacement: 步骤 4 中的图像 2,3 Motorola MOTO W755 Cell Phone Camera Replacement: 步骤 4 中的图像 3,3
    • Using the flat end of the plastic opening tool, insert it underneath the plastic cover on the top right corner.
    • Move the opening tool around the phone counter clockwise.
    • Pop the plastic cover off by twisting the plastic covering tool.
  5. Motorola MOTO W755 Cell Phone Camera Replacement: 步骤 5 中的图像 1,2 Motorola MOTO W755 Cell Phone Camera Replacement: 步骤 5 中的图像 2,2
    • Using a flat head screwdriver, insert it between the metal logic board casing and the top portion of the phone
    • Move the plastic opening tool around the phone until part of the casting is popped off.
    • You will need to pop in the four plastic fasteners individually from the metal casing to remove it
    • Be careful not to rip the cable ribbons that are attached to the logic board and casing
  6. Motorola MOTO W755 Cell Phone Camera Replacement: 步骤 6 中的图像 1,1
    • Use the flat end of the plastic opening tool to unclip the cable ribbon from the logic board
  7. Motorola MOTO W755 Cell Phone Camera Replacement: 步骤 7 中的图像 1,1
    • You now have the top panel completely detached.
  8. Motorola MOTO W755 Cell Phone Camera Replacement, Camera: 步骤 8 中的图像 1,1
    • Using the plastic opening tool, peel back the plastic cover that is glued on top of the camera lens.
  9. Motorola MOTO W755 Cell Phone Camera Replacement: 步骤 9 中的图像 1,2 Motorola MOTO W755 Cell Phone Camera Replacement: 步骤 9 中的图像 2,2
    • Using the plastic opening tool, gently push the camera out from the front.
    • Part of the foam holding the camera will rip from the adhesive.
结论
C Miller
于06/25/12注册
56 声望
创作了3篇指南
团队
Cal Poly, Team 1-3, Regan SU 2012 Cal Poly, Team 1-3, Regan SU 2012 的会员
CPSU-REGAN-SU12S1G3
2 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,150
