当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Push in the battery release button.
Pull out battery.
Remove the two rubber plugs on the top of the device by pushing them up and out of the phone.
Remove the four 1cm Phillips #0 screws from the top and bottom of the phone.
Use a plastic opening tool to remove the keyboard cover by prying up on its perimeter.
Remove the eight 4mm Phillips #00 screws from the keyboard cover.
Remove the keyboard cover.
Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
Pull the ribbon cable out of the socket.
Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
Remove the keyboard from the device.
Pull the black rubber tabs up gently and remove them.
Using your finger, or spudger, push the motherboard out from the bottom.
Remove the three Phillips #00 screws from the motherboard:
Two 3mm screws.
One 1mm screw.
Disconnect the speaker from the motherboard.
取消:我没有完成这个指南。
与2其他贡献者
于02/22/18注册
555 声望
创作了5篇指南
徽章: 5
+ 2更多徽章
USFT-CAGLE-S18S1G6
4 名成员
创作了6篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 149
