本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will help the user to replace an old or faulty antenna. This will help to boost signal and connectivity in an aging or broken device. The antenna of the MC55 series is known to wear out with regular use and will fail to function regularly over time.
你所需要的
Remove the two rubber plugs on the top of the device by pushing them up and out of the phone.
Remove the the 3mm Phillips #00 screws from the flex cable cover and antenna.
Remove the antenna.
Remove the flex cable cover.
Remove the antenna connector (red box).
This is a snap-on connector, which can be removed by applying a gentle pull straight up from the motherboard.
