简介
The Baby Unit Microphone is vital because it allows you to communicate between the two monitors in different rooms. You will need a soldering kit to successfully install a new microphone.
你所需要的
Using precision tweezers, remove the four rubber feet from the bottom of the baby unit.
Using a Phillips #1 screwdriver, remove the 9.5mm screws that were under the rubber feet.
Open the base of the baby unit.
4等其他人完成本指南。
