简介
To start you will need to remove the bottom case of the lapdock as described in the guide. After doing this you will need to remove the lapdock battery. Then you will follow by unplugging the phone adapter cord from the motherboard. Then you will be able to remove and replace the cord.
你所需要的
To take off the Keyboard there are three tabs at the top of the Keyboard in the locations shown in the picture that you must press and unclip. They are located behind each of the keys that are removed.
Unplug the two connections to the motherboard to free the adapter cable.
