跳转到主内容
Motorola Lapdock 100 Motherboard Replacement
你所需要的
  1. Motorola Lapdock 100 Motherboard Replacement, Lower Case: 步骤 1 中的图像 1,2 Motorola Lapdock 100 Motherboard Replacement, Lower Case: 步骤 1 中的图像 2,2
    • To take off the Keyboard there are three tabs at the top of the Keyboard in the locations shown in the picture that you must press and unclip. They are located behind each of the keys that are removed.
    • You do not need to remove any keys to unclip the keyboard. We did this for picture purposes only.
  2. Motorola Lapdock 100 Motherboard Replacement: 步骤 2 中的图像 1,1
    • You can use a small metal spudger to depress each tab to avoid scratching the keyboard.
  3. Motorola Lapdock 100 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Lift up keyboard so that you are able to see the ribbon cable connected to the contact.
  4. Motorola Lapdock 100 Motherboard Replacement: 步骤 4 中的图像 1,2 Motorola Lapdock 100 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Flip up the ZIF connector holding the ribbon cable on the contact as shown in the two pictures and then gently disconnect the ribbon cable.
  5. Motorola Lapdock 100 Motherboard Replacement: 步骤 5 中的图像 1,2 Motorola Lapdock 100 Motherboard Replacement: 步骤 5 中的图像 2,2
    • After we remove the Keyboard, you can clearly see the screws under it. Remove the ten 3mm long phillips head screws.
  6. Motorola Lapdock 100 Motherboard Replacement: 步骤 6 中的图像 1,3 Motorola Lapdock 100 Motherboard Replacement: 步骤 6 中的图像 2,3 Motorola Lapdock 100 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Flip over the Lapdock and remove the four 3.5mm long phillips head screws from the bottom.
  7. Motorola Lapdock 100 Motherboard Replacement: 步骤 7 中的图像 1,2 Motorola Lapdock 100 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Use a plastic prying tool to take off the bottom case. Make sure that all of the clips are unclipped before trying to remove the case.
  8. Motorola Lapdock 100 Motherboard Replacement, Battery: 步骤 8 中的图像 1,2 Motorola Lapdock 100 Motherboard Replacement, Battery: 步骤 8 中的图像 2,2
    • Unplug battery from motherboard.
  9. Motorola Lapdock 100 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the battery.
  10. Motorola Lapdock 100 Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,1
    • Remove the two 2mm long phillips head screws from the left speaker and move it away from the motherboard.
  11. Motorola Lapdock 100 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Unplug the speakers from the motherboard
  12. Motorola Lapdock 100 Motherboard Replacement: 步骤 12 中的图像 1,2 Motorola Lapdock 100 Motherboard Replacement: 步骤 12 中的图像 2,2
    • Remove the two 2mm long phillips head screws that are holding down the motherboard.
  13. Motorola Lapdock 100 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Disconnect the ribbon cable that attaches to the trackpad from the motherboard.
  14. Motorola Lapdock 100 Motherboard Replacement: 步骤 14 中的图像 1,2 Motorola Lapdock 100 Motherboard Replacement: 步骤 14 中的图像 2,2
    • Disconnect the two wires that attach to the screen from the motherboard.
  15. Motorola Lapdock 100 Motherboard Replacement: 步骤 15 中的图像 1,1
    • The motherboard and phone adapter cable should both be free from the lapdock.
  16. Motorola Lapdock 100 Motherboard Replacement: 步骤 16 中的图像 1,2 Motorola Lapdock 100 Motherboard Replacement: 步骤 16 中的图像 2,2
    • Unplug the two phone adapter cable connections to the motherboard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 21
总计 876
