跳转到主内容
Motorola Lapdock 100 Keyboard Replacement
你所需要的
  1. Motorola Lapdock 100 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Motorola Lapdock 100 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • To take off the Keyboard there are three tabs at the top of the Keyboard in the locations shown in the picture that you must press and unclip. They are located behind each of the keys that are removed. You do not need to remove any keys to unclip the keyboard.
  2. Motorola Lapdock 100 Keyboard Replacement: 步骤 2 中的图像 1,3 Motorola Lapdock 100 Keyboard Replacement: 步骤 2 中的图像 2,3 Motorola Lapdock 100 Keyboard Replacement: 步骤 2 中的图像 3,3
    • You can use the a small metal spudger to depress each tab to avoid scratching the keyboard.
  3. Motorola Lapdock 100 Keyboard Replacement: 步骤 3 中的图像 1,2 Motorola Lapdock 100 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Flip up white clip holding the ribbon cable on the contact as shown in the two pictures and then gently disconnect the ribbon cable.
  4. Motorola Lapdock 100 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Remove the keyboard
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 347
