跳转到主内容
Motorola Krzr K1m keyboard repalcement
你所需要的
  1. Motorola Krzr K1m keyboard repalcement, Keypad: 步骤 1 中的图像 1,2 Motorola Krzr K1m keyboard repalcement, Keypad: 步骤 1 中的图像 2,2
    • Remove the battery with your fingers by pulling the battery from the top corners labeled "Pull Here" located on the left and right side of the top of the battery.
    • Remove the battery.
  2. Motorola Krzr K1m keyboard repalcement: 步骤 2 中的图像 1,3 Motorola Krzr K1m keyboard repalcement: 步骤 2 中的图像 2,3 Motorola Krzr K1m keyboard repalcement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Spudger
    $3.99
    购买
    • To begin detaching the battery dock, unscrew the 4 black screws on each corner of the phone with the T5 Torx Screwdriver.
    • Lift up the battery dock where the hinges are located. Carefully insert the T5 Torx Screwdriver in between the battery dock and the back plate of the battery. (See the picture to locate the hinges)
    • Remove the battery dock by popping it up with The Spudger.
  3. Motorola Krzr K1m keyboard repalcement: 步骤 3 中的图像 1,3 Motorola Krzr K1m keyboard repalcement: 步骤 3 中的图像 2,3 Motorola Krzr K1m keyboard repalcement: 步骤 3 中的图像 3,3
    • To remove the chip board, first unplug the flex cable from the logic board with tweezers.
    • Lift up the logic board from the bottom flip with your fingers.
    • Remove the logic board.
  4. Motorola Krzr K1m keyboard repalcement: 步骤 4 中的图像 1,2 Motorola Krzr K1m keyboard repalcement: 步骤 4 中的图像 2,2
    • Gently pop off the keypad with your fingers.
    • Once the keypad is removed, follow all of the steps in reverse order to replace the old keypad with the new keypad.
结论
团队
Cal Poly, Team 11-1, Forte Winter 2010 Cal Poly, Team 11-1, Forte Winter 2010 的会员
CPSU-FORTE-W10S11G1
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 4,395
