跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide will provide the steps on how to disassemble a broken or cracked LCD(Liquid Crystal Display) screen for the Motorola K1m cellphone. It will also give you the instructions to replace the broken LCD screen with a new and working one. Once you finish this guide you will have a new working LCD screen.
    • Begin by removing the trim piece from around the front face plate.
    • Be very careful when dealing with the trim. It is very delicate, so be cautious when approching this next part.
    • Using your fingers or The Spudger get underneath the trim. Start by applying enough force to pry the trim off.
    • Be patient when trying to pry off the trim. The tape attaching the trim to the phone is very strong. Just be persistent and patient and it will eventually give.
    • Remove the trim piece.
  1. Once you have removed the trim you will see 4 gold screws at the corners of the phone. Using a T5 Torx Screwdriver, remove the screws. Once you have removed the trim you will see 4 gold screws at the corners of the phone. Using a T5 Torx Screwdriver, remove the screws.
    • Once you have removed the trim you will see 4 gold screws at the corners of the phone. Using a T5 Torx Screwdriver, remove the screws.
    • Gently use The Spudger towards the edge of the phone and lift the face plate off.
    • The touch-sensitive keys and chip board/LCD screen (which is green) may remain attached to the face plate because of the glue.
    • Gently hold the green logic board down as you lift the face plate apart from it.
    • Remove the face plate.
  2. Gently, with your fingers or a tweezer, lift the orange flex cable apart from the pin connector it is connected to. Gently remove the green logic board/LCD (Liquid Crystal Display) screen away from the phone. Replace with new green logic board/LCD screen.
    • Gently, with your fingers or a tweezer, lift the orange flex cable apart from the pin connector it is connected to.
    • Gently remove the green logic board/LCD (Liquid Crystal Display) screen away from the phone.
    • Replace with new green logic board/LCD screen.
    • To reassemble the phone, follow of the steps in reverse order.
结论
2等其他人完成本指南。
Jennifer Hudiono
于2010年01月13日注册
42 信誉积分
创作了4篇指南
团队
Cal Poly, Team 11-1, Forte Winter 2010 Cal Poly, Team 11-1, Forte Winter 2010 的会员
CPSU-FORTE-W10S11G1
5 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 6,344
