跳转到主内容
简介
This guide will show you how to detach the batter on the Motorola KRZR. It will give you instructions on how to disassemble the back cover of the KRZR in order to access the battery.
  1. Push down on the silver tab located at the top center of the back of the Motorola K1m cellphone. Push down on the silver tab located at the top center of the back of the Motorola K1m cellphone.
    • Push down on the silver tab located at the top center of the back of the Motorola K1m cellphone.
  2. PC 笔记本电池
    An easy fix for a big power boost.
    现在开始购物
    PC 笔记本电池
    现在开始购物
  3. While pushing down on the silver tab, slide the back cover towards the silver tab.
    • While pushing down on the silver tab, slide the back cover towards the silver tab.
    • Remove the back cover.
  4. Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
    • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
    • Replace the old battery with the new battery.
    • Follow all of the steps to remove the battery in reverse order to reassemble.
结论
Jennifer Hudiono
于2010年01月13日注册
42 信誉积分
创作了4篇指南
团队
Cal Poly, Team 11-1, Forte Winter 2010 Cal Poly, Team 11-1, Forte Winter 2010 的会员
CPSU-FORTE-W10S11G1
5 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 5
过去的30天: 11
总计 4,879
