跳转到主内容
Motorola Hyper Android Phone Charging port Replacement
你所需要的
  1. Motorola Hyper Android Phone Charging port Replacement, Finding the seam  to remove.: 步骤 1 中的图像 1,1
    • Charging port replacement
  2. Motorola Hyper Android Phone Charging port Replacement, Teardown - Remove sim tray: 步骤 2 中的图像 1,3 Motorola Hyper Android Phone Charging port Replacement, Teardown - Remove sim tray: 步骤 2 中的图像 2,3 Motorola Hyper Android Phone Charging port Replacement, Teardown - Remove sim tray: 步骤 2 中的图像 3,3
    • Use a heat gun or hair dryer to soften the adhesive on the rear cover
  3. Motorola Hyper Android Phone Charging port Replacement: 步骤 3 中的图像 1,3 Motorola Hyper Android Phone Charging port Replacement: 步骤 3 中的图像 2,3 Motorola Hyper Android Phone Charging port Replacement: 步骤 3 中的图像 3,3
    • Start at the camera and go around the edge with an Opening Pick. Pry the last bit around the camera.
  4. Motorola Hyper Android Phone Charging port Replacement, Opening cover: 步骤 4 中的图像 1,3 Motorola Hyper Android Phone Charging port Replacement, Opening cover: 步骤 4 中的图像 2,3 Motorola Hyper Android Phone Charging port Replacement, Opening cover: 步骤 4 中的图像 3,3
    • Open case from the on button side face down. You will need a T4 bit driver.
  5. Motorola Hyper Android Phone Charging port Replacement, Remove  screws for vent: 步骤 5 中的图像 1,3 Motorola Hyper Android Phone Charging port Replacement, Remove  screws for vent: 步骤 5 中的图像 2,3 Motorola Hyper Android Phone Charging port Replacement, Remove  screws for vent: 步骤 5 中的图像 3,3
    • Remove 6 T4 screws. Remove mini fan vent.
  6. Motorola Hyper Android Phone Charging port Replacement, Remove charging wires: 步骤 6 中的图像 1,3 Motorola Hyper Android Phone Charging port Replacement, Remove charging wires: 步骤 6 中的图像 2,3 Motorola Hyper Android Phone Charging port Replacement, Remove charging wires: 步骤 6 中的图像 3,3
    • Pry off the black and white wires with a pry tool. Remove Philips screw.
  7. Motorola Hyper Android Phone Charging port Replacement, Remove charge port: 步骤 7 中的图像 1,3 Motorola Hyper Android Phone Charging port Replacement, Remove charge port: 步骤 7 中的图像 2,3 Motorola Hyper Android Phone Charging port Replacement, Remove charge port: 步骤 7 中的图像 3,3
    • Remove and replace the charge port with new one.
  8. Motorola Hyper Android Phone Charging port Replacement, Assembly: 步骤 8 中的图像 1,3 Motorola Hyper Android Phone Charging port Replacement, Assembly: 步骤 8 中的图像 2,3 Motorola Hyper Android Phone Charging port Replacement, Assembly: 步骤 8 中的图像 3,3
    • Install items in reverse order
  9. Motorola Hyper Android Phone Charging port Replacement, Remove old gasket material: 步骤 9 中的图像 1,3 Motorola Hyper Android Phone Charging port Replacement, Remove old gasket material: 步骤 9 中的图像 2,3 Motorola Hyper Android Phone Charging port Replacement, Remove old gasket material: 步骤 9 中的图像 3,3
    • Clean all the gasket off.
    • There is only room for one layer, for a smooth cover fit.
  10. Motorola Hyper Android Phone Charging port Replacement, Remove finger print reader cable: 步骤 10 中的图像 1,3 Motorola Hyper Android Phone Charging port Replacement, Remove finger print reader cable: 步骤 10 中的图像 2,3 Motorola Hyper Android Phone Charging port Replacement, Remove finger print reader cable: 步骤 10 中的图像 3,3
    • Remove finger print reader cable to install new cover gasket. surface must be clean so the cover sits tight with no gaps.
  11. Motorola Hyper Android Phone Charging port Replacement, Install gasket: 步骤 11 中的图像 1,3 Motorola Hyper Android Phone Charging port Replacement, Install gasket: 步骤 11 中的图像 2,3 Motorola Hyper Android Phone Charging port Replacement, Install gasket: 步骤 11 中的图像 3,3
    • Make sure the gasket is firmly in place.
  12. Motorola Hyper Android Phone Charging port Replacement, Replace FPR cable: 步骤 12 中的图像 1,3 Motorola Hyper Android Phone Charging port Replacement, Replace FPR cable: 步骤 12 中的图像 2,3 Motorola Hyper Android Phone Charging port Replacement, Replace FPR cable: 步骤 12 中的图像 3,3
    • Install FPR cable.
    • Install the keep.
    • Put tape on the cover to align the edges.
  13. Motorola Hyper Android Phone Charging port Replacement, Finish installing cover: 步骤 13 中的图像 1,3 Motorola Hyper Android Phone Charging port Replacement, Finish installing cover: 步骤 13 中的图像 2,3 Motorola Hyper Android Phone Charging port Replacement, Finish installing cover: 步骤 13 中的图像 3,3
    • Tape helps align cover for a smooth install.
    • Press the cover on to seal.
结论
3等其他人完成本指南。
wes zab
于06/20/22注册
277 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 66
总计 894
