跳转到主内容
Motorola Edge (2022) Camera Bezel Replacement
你所需要的
  1. Motorola Edge (2022) Camera Bezel Replacement, Heat the right edge: 步骤 1 中的图像 1,1
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Motorola Edge (2022) Camera Bezel Replacement, Insert an opening pick: 步骤 2 中的图像 1,2 Motorola Edge (2022) Camera Bezel Replacement, Insert an opening pick: 步骤 2 中的图像 2,2
    • Insert an opening pick between the camera bezel and the back cover.
  3. Motorola Edge (2022) Camera Bezel Replacement, Slice the camera bezel adhesive: 步骤 3 中的图像 1,2 Motorola Edge (2022) Camera Bezel Replacement, Slice the camera bezel adhesive: 步骤 3 中的图像 2,2
    • Slide the pick around the perimeter of the camera bezel to slice all the adhesive securing the bezel.
    • You may have to repeat this process multiple times to completely cut all of the adhesive.
  4. Motorola Edge (2022) Camera Bezel Replacement, Remove the camera bezel: 步骤 4 中的图像 1,2 Motorola Edge (2022) Camera Bezel Replacement, Remove the camera bezel: 步骤 4 中的图像 2,2
    • Lift the camera bezel away from the phone and remove it.
结论
To reassemble your device, follow the instructions in reverse order.
Spencer Day
于09/14/22注册
55,203 声望
创作了408篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,430篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 338
