跳转到主内容
Motorola Droid X Rear Housing Replacement
你所需要的
  1. Motorola Droid X Rear Housing Replacement, Rear Housing: 步骤 1 中的图像 1,1
    • First begin by sliding down the battery door, and place that to the side.
  2. Motorola Droid X Rear Housing Replacement: 步骤 2 中的图像 1,2 Motorola Droid X Rear Housing Replacement: 步骤 2 中的图像 2,2
    • Pull the battery tab up, and remove the battery from the phone.
  3. Motorola Droid X Rear Housing Replacement: 步骤 3 中的图像 1,1
    • Remove the two T5 screws as shown by the markers.
  4. Motorola Droid X Rear Housing Replacement: 步骤 4 中的图像 1,2 Motorola Droid X Rear Housing Replacement: 步骤 4 中的图像 2,2
    • Flip the phone over to the front, and slide an opening tool as shown between the metal housing & the plastic piece covering the lower portion of the phone by the microphone.
  5. Motorola Droid X Rear Housing Replacement: 步骤 5 中的图像 1,1
    • Now do the same to the top of the phone with your opening tool as shown to remove the other plastic piece covering the top of the phone.
  6. Motorola Droid X Rear Housing Replacement: 步骤 6 中的图像 1,2 Motorola Droid X Rear Housing Replacement: 步骤 6 中的图像 2,2
    • Now with both of the plastic covers removed, remove the 4 silver T5 screws on the top and bottom of the unit as shown.
  7. Motorola Droid X Rear Housing Replacement: 步骤 7 中的图像 1,3 Motorola Droid X Rear Housing Replacement: 步骤 7 中的图像 2,3 Motorola Droid X Rear Housing Replacement: 步骤 7 中的图像 3,3
    • Starting on the top right side of the phone, run your opening tool down the side and all the way around with slight force to begin to separate the back housing from the front assembly.
    • Look at the two pictures showing the clips to help you know where they are located.
  8. Motorola Droid X Rear Housing Replacement: 步骤 8 中的图像 1,1
    • You can easily release the two clips on the right side (nearest the headphone jack) by pressing in the black plastic tabs inside the metal clips. The torx screwdriver you used earlier works well for this.
  9. Motorola Droid X Rear Housing Replacement: 步骤 9 中的图像 1,1
    • Congratulations! You have now successfully removed your back housing from your Droid X!
结论
7等其他人完成本指南。
Josh Forester
于11/28/10注册
2,497 声望
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 5,588
