配件
无需配件。
Follow removal of rear housing guide. This should be your starting point.
  • Follow removal of rear housing guide. This should be your starting point.
添加评论
Using your fingernail or an opening tool, peel back the first layer of tape, located toward the left side of the phone. The circuit wiring should peel away with the tape. If not, remove the circuit wiring from the terminal.
  • Using your fingernail or an opening tool, peel back the first layer of tape, located toward the left side of the phone. The circuit wiring should peel away with the tape. If not, remove the circuit wiring from the terminal.
添加评论
  • Peel away second layer of tape and smaller circuit wiring.
  • Use caution as this wiring is extremely fragile.
添加评论
  • Using tweezers, remove wire connecting motherboard to small circuitboard at the bottom right of camera housing. Remove each head of the wire individually.
添加评论
  • Pry up motherboard using opening tool to pry circuitboard away from two clasps on the left side of phone.
添加评论
  • Pull camera up from rear housing of phone using fingers.
添加评论
  • Remove final circuit from terminal on the bottom side of the motherboard using the opening tool.
添加评论
  • Completed.
添加评论
结论
Genevieve Abbiss
于2012年09月27日注册
19 信誉积分
创作了2篇指南
团队
Ohio State, Team 1-1, Buehl Fall 2012 Ohio State, Team 1-1, Buehl Fall 2012 的会员
OSU-BUEHL-F12S1G1
4 名成员
创作了3篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 1,225
