跳转到主内容
加入维修社区 - 创建账户
Motorola Droid X Camera Replacement
你所需要的
  1. Motorola Droid X Camera Replacement, Battery: 步骤 1 中的图像 1,2 Motorola Droid X Camera Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the power button at the top of the phone. Depress power button for 2 seconds until a menu appears.
  2. Motorola Droid X Camera Replacement: 步骤 2 中的图像 1,2 Motorola Droid X Camera Replacement: 步骤 2 中的图像 2,2
    • Once the menu appears, select the "power off" option. Wait until the phone is completely off.
  3. Motorola Droid X Camera Replacement: 步骤 3 中的图像 1,2 Motorola Droid X Camera Replacement: 步骤 3 中的图像 2,2
    • Place thumb on the back cover, and push down towards the bottom of the device. Once the cover releases, pull it away from the phone and set it aside.
  4. Motorola Droid X Camera Replacement: 步骤 4 中的图像 1,2 Motorola Droid X Camera Replacement: 步骤 4 中的图像 2,2
    • Find the yellow pull tab located in the upper left corner. Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case.
  5. Motorola Droid X Camera Replacement: 步骤 5 中的图像 1,1
    • The battery has been successfully removed.
  6. Motorola Droid X Camera Replacement, Motorola Droid X Rear Housing: 步骤 6 中的图像 1,1
    • Remove the micro SD card from its connector.
  7. Motorola Droid X Camera Replacement: 步骤 7 中的图像 1,3 Motorola Droid X Camera Replacement: 步骤 7 中的图像 2,3 Motorola Droid X Camera Replacement: 步骤 7 中的图像 3,3
    • Locate the seam between the back case and the end cover on the top edge of the phone.
    • Use the plastic opening tool to detach the two clips by wedging the tool into the right side of the seam and moving right to left. Once the cover comes off set it aside
  8. Motorola Droid X Camera Replacement: 步骤 8 中的图像 1,3 Motorola Droid X Camera Replacement: 步骤 8 中的图像 2,3 Motorola Droid X Camera Replacement: 步骤 8 中的图像 3,3
    • Repeat step 2 on the bottom cover.
  9. Motorola Droid X Camera Replacement: 步骤 9 中的图像 1,3 Motorola Droid X Camera Replacement: 步骤 9 中的图像 2,3 Motorola Droid X Camera Replacement: 步骤 9 中的图像 3,3
    • Use a T5 Torx screwdriver to remove the screws in each corner of the phone.
    • The screws are very small so make sure not to lose them.
  10. Motorola Droid X Camera Replacement: 步骤 10 中的图像 1,2 Motorola Droid X Camera Replacement: 步骤 10 中的图像 2,2
    • Flip the phone over and locate the screw on the middle of the left side. Unscrew it using the T5 Torx screwdriver and set it aside.
  11. Motorola Droid X Camera Replacement: 步骤 11 中的图像 1,2 Motorola Droid X Camera Replacement: 步骤 11 中的图像 2,2
    • Identify the screw located in the bottom right corner of the battery case. Remove the screw with a T5 (or in some cases T6) torx screwdriver and set it aside.
  12. Motorola Droid X Camera Replacement: 步骤 12 中的图像 1,2 Motorola Droid X Camera Replacement: 步骤 12 中的图像 2,2
    • Locate the seam along the right edge of the phone. Use the prying tool to disconnect the two clips along the edge.
  13. Motorola Droid X Camera Replacement: 步骤 13 中的图像 1,3 Motorola Droid X Camera Replacement: 步骤 13 中的图像 2,3 Motorola Droid X Camera Replacement: 步骤 13 中的图像 3,3
    • Locate the two clips on the inside of the case and use the spudger tool to detach them from the case. To detach each clip, use the sharp end to press the small, black plastic in the center of the clip.
  14. Motorola Droid X Camera Replacement: 步骤 14 中的图像 1,2 Motorola Droid X Camera Replacement: 步骤 14 中的图像 2,2
    • After the clips are detached, remove the back case and set it aside.
  15. Motorola Droid X Camera Replacement, Motherboard: 步骤 15 中的图像 1,1
    • Remove the screws along both sides of the motherboard using a T3 Torx screwdriver. On some phones this may require a #1 Phillips Screw Driver.
  16. Motorola Droid X Camera Replacement: 步骤 16 中的图像 1,2 Motorola Droid X Camera Replacement: 步骤 16 中的图像 2,2
    在这个步骤中使用的工具:
    • Carefully remove the white connecting wire from the motherboard using tweezers.
    • Use caution, this wire is delicate.
  17. Motorola Droid X Camera Replacement: 步骤 17 中的图像 1,2 Motorola Droid X Camera Replacement: 步骤 17 中的图像 2,2
    • Scrape away the electrical tape that covers the LCD and digitizer cable using the spudger tool or a fingernail.
  18. Motorola Droid X Camera Replacement: 步骤 18 中的图像 1,1
    • Use the spudger tool to pop the Digitizer cable off of the motherboard.
  19. Motorola Droid X Camera Replacement: 步骤 19 中的图像 1,1
    • Carefully flip the small white connector up and away from the motherboard.
  20. Motorola Droid X Camera Replacement: 步骤 20 中的图像 1,1
    • Gently pull the flat gold cable out from the connector.
  21. Motorola Droid X Camera Replacement: 步骤 21 中的图像 1,1
    • Carefully lift the motherboard and camera module up. Do not remove it from the phone!
  22. Motorola Droid X Camera Replacement: 步骤 22 中的图像 1,1
    • Using the spudger tool, pop the black cable connector off of the motherboard.
  23. Motorola Droid X Camera Replacement: 步骤 23 中的图像 1,1
    • It is to safe remove the motherboard from the phone.
  24. Motorola Droid X Camera Replacement, Camera: 步骤 24 中的图像 1,1
    • Gently peel the camera's orange and gold connection cable from the motherboard.
  25. Motorola Droid X Camera Replacement: 步骤 25 中的图像 1,1
    • Remove the black electrical tape covering the cameras connection cable.
  26. Motorola Droid X Camera Replacement: 步骤 26 中的图像 1,1
    • Flip up the small white connector. Then gently pull the orange cable out of the connecter.
  27. Motorola Droid X Camera Replacement: 步骤 27 中的图像 1,1
    • Reconnect the camera module by pushing the black end of the flat cable on the camera module into the white connector on the motherboard.
结论
另外一个人完成了本指南。
Sam Johnston
于10/03/12注册
576 声望
创作了4篇指南
团队
Cal Poly, Team 18-40, Regan Fall 2012 Cal Poly, Team 18-40, Regan Fall 2012 的会员
CPSU-REGAN-F12S18G40
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 24
总计 2,343
