跳转到主内容
Motorola Droid Turbo Vibrator Replacement
你所需要的
  1. Motorola Droid Turbo Vibrator Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Motorola Droid Turbo Vibrator Replacement: 步骤 2 中的图像 1,2 Motorola Droid Turbo Vibrator Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
  3. Motorola Droid Turbo Vibrator Replacement, Midframe: 步骤 3 中的图像 1,1
    • Remove the midframe bezel.
  4. Motorola Droid Turbo Vibrator Replacement: 步骤 4 中的图像 1,1
    • Remove the four Torx T5 screws securing the midframe plate.
  5. Motorola Droid Turbo Vibrator Replacement: 步骤 5 中的图像 1,1
    • Remove the midframe.
  6. Motorola Droid Turbo Vibrator Replacement, Vibrator: 步骤 6 中的图像 1,2 Motorola Droid Turbo Vibrator Replacement, Vibrator: 步骤 6 中的图像 2,2
    • Use the pointed end of a spudger to gently pry the vibrator up and away from the midframe.
结论
Geoff Wacker
于09/30/13注册
89,889 声望
创作了89篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,198
