跳转到主内容
Motorola Droid Turbo Front Facing Camera Replacement
你所需要的
  1. Motorola Droid Turbo Front Facing Camera Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Motorola Droid Turbo Front Facing Camera Replacement: 步骤 2 中的图像 1,2 Motorola Droid Turbo Front Facing Camera Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
  3. Motorola Droid Turbo Front Facing Camera Replacement, Midframe: 步骤 3 中的图像 1,1
    • Remove the midframe bezel.
  4. Motorola Droid Turbo Front Facing Camera Replacement: 步骤 4 中的图像 1,1
    • Remove the four Torx T5 screws securing the midframe plate.
  5. Motorola Droid Turbo Front Facing Camera Replacement: 步骤 5 中的图像 1,1
    • Remove the midframe.
  6. Motorola Droid Turbo Front Facing Camera Replacement, Front Facing Camera: 步骤 6 中的图像 1,2 Motorola Droid Turbo Front Facing Camera Replacement, Front Facing Camera: 步骤 6 中的图像 2,2
    • Use the pointed end of a spudger to flip up the black retaining flap of the front facing camera's ZIF connector.
  7. Motorola Droid Turbo Front Facing Camera Replacement: 步骤 7 中的图像 1,2 Motorola Droid Turbo Front Facing Camera Replacement: 步骤 7 中的图像 2,2
    • Remove the front-facing camera.
结论
Luis Arangu
于01/20/16注册
1,127 声望
创作了3篇指南
团队
USF Tampa, Team 15-5, Remmell Spring 2016 USF Tampa, Team 15-5, Remmell Spring 2016 的会员
USFT-REMMELL-S16S15G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 1,722
