跳转到主内容
Motorola Droid Turbo Dual LED Flash Board Replacement
你所需要的
  1. Motorola Droid Turbo Dual LED Flash Board Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Motorola Droid Turbo Dual LED Flash Board Replacement: 步骤 2 中的图像 1,2 Motorola Droid Turbo Dual LED Flash Board Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
  3. Motorola Droid Turbo Dual LED Flash Board Replacement, Dual LED Flash Board: 步骤 3 中的图像 1,2 Motorola Droid Turbo Dual LED Flash Board Replacement, Dual LED Flash Board: 步骤 3 中的图像 2,2
    • Use a Jimmy to separate the dual LED flash board from the rear case.
    • The board is secured with some light adhesive, so some force may be required.
结论
另外一个人完成了本指南。
Geoff Wacker
于09/30/13注册
89,934 声望
创作了89篇指南
一条评论
Gostaria se possível alguem tenha o manual de serviço do Moto maxx XT 1225 ou 1254. Porf favor , ddani8260@gmail.com
Daniel Gomes - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 959
