跳转到主内容
Motorola Droid RAZR Maxx Back Cover Replacement
你所需要的
  1. Motorola Droid RAZR Maxx Back Cover Replacement, Taking off the Back Cover: 步骤 1 中的图像 1,2 Motorola Droid RAZR Maxx Back Cover Replacement, Taking off the Back Cover: 步骤 1 中的图像 2,2
    • Remove the SIM card.
    • Remove the microSD card.
    • Insert the plastic opening tool between the back cover and the front piece of the case, freeing the plastic clips between the phone.
    • Do this along the back right side of the phone cover until you reach the top.
  2. Motorola Droid RAZR Maxx Back Cover Replacement: 步骤 2 中的图像 1,2 Motorola Droid RAZR Maxx Back Cover Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to carefully work your way around the top of the phone, freeing the plastic clips.
    • Be cautious when using the tool around the top of the device because the plastic case is very thin and could easily be cracked or snapped.
    • Continue using the tool and pry down the remaining side and the bottom of the phone.
  3. Motorola Droid RAZR Maxx Back Cover Replacement: 步骤 3 中的图像 1,3 Motorola Droid RAZR Maxx Back Cover Replacement: 步骤 3 中的图像 2,3 Motorola Droid RAZR Maxx Back Cover Replacement: 步骤 3 中的图像 3,3
    • With all the plastic clips released, pull away the back cover from the phone to remove it.
    • The back cover is attached to the battery with a large amount of adhesive. Some force may be required to pull the back cover from the phone.
    • The back cover is very durable and will not break from some bending or pulling.
结论
4等其他人完成本指南。
sean crocker
于10/08/14注册
341 声望
撰写一个指南
团队
USF Tampa, Team 14-6, Leahy Fall 2014 USF Tampa, Team 14-6, Leahy Fall 2014 的会员
USFT-LEAHY-F14S14G6
4 名成员
创作了10篇指南
2条评论
Ok so I have the cover off of the back of my Droid Razr Maxx HD? But where is it that I can purchase the new back cover? I figured you guys would have at least a hyper link to somewhere I could buy it? Instead of just having instructions on how to remove the backing? Thanks Very Respectfully, Joey K
sailorjt1985 - 回复
I have same problem. Need new back cover.
TheShellex - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 2,765
