跳转到主内容
Motorola Droid RAZR M Motherboard Replacement
你所需要的
  1. Motorola Droid RAZR M Motherboard Replacement, Front Assembly: 步骤 1 中的图像 1,3 Motorola Droid RAZR M Motherboard Replacement, Front Assembly: 步骤 1 中的图像 2,3 Motorola Droid RAZR M Motherboard Replacement, Front Assembly: 步骤 1 中的图像 3,3
    • Open the small latch on the left side of the device by lifting gently with your finger, exposing the SIM card and microSD card slots.
    • If either of these cards are present, remove them to prevent damaging them while taking apart the phone. Our device does not have either.
    • Close the latch once the two cards are removed.
  2. Motorola Droid RAZR M Motherboard Replacement: 步骤 2 中的图像 1,3 Motorola Droid RAZR M Motherboard Replacement: 步骤 2 中的图像 2,3 Motorola Droid RAZR M Motherboard Replacement: 步骤 2 中的图像 3,3
    • Remove the six 4mm T3 Torx screws. There are 3 on each side of the device.
  3. Motorola Droid RAZR M Motherboard Replacement: 步骤 3 中的图像 1,3 Motorola Droid RAZR M Motherboard Replacement: 步骤 3 中的图像 2,3 Motorola Droid RAZR M Motherboard Replacement: 步骤 3 中的图像 3,3
    • Run the plastic opening tool under the bottom edge of the phone to detach the small plastic cover below the Verizon logo.
    • It will take some force to remove this piece. Work around the bottom corners to unlatch the two hooks holding the piece in place.
    • The small plastic hooks can break during removal. Be careful that you don't damage them, but it will take some force to get them undone.
    • Once the plastic cover is detached, pull the piece away with your fingers.
  4. Motorola Droid RAZR M Motherboard Replacement: 步骤 4 中的图像 1,2 Motorola Droid RAZR M Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the three T4 Torx screws. There are three at the bottom of the device.
  5. Motorola Droid RAZR M Motherboard Replacement: 步骤 5 中的图像 1,3 Motorola Droid RAZR M Motherboard Replacement: 步骤 5 中的图像 2,3 Motorola Droid RAZR M Motherboard Replacement: 步骤 5 中的图像 3,3
    • Using the plastic opening tool, peel away the silver Motorola plate at the top of the phone. There is a fair amount of adhesive underneath, so you may have to pry it from a few different angles.
    • As soon as you can get your finger underneath, pull away the silver plate.
  6. Motorola Droid RAZR M Motherboard Replacement: 步骤 6 中的图像 1,2 Motorola Droid RAZR M Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove the two 7mm T4 Torx screws at the top of the device.
  7. Motorola Droid RAZR M Motherboard Replacement: 步骤 7 中的图像 1,3 Motorola Droid RAZR M Motherboard Replacement: 步骤 7 中的图像 2,3 Motorola Droid RAZR M Motherboard Replacement: 步骤 7 中的图像 3,3
    • When you detach the front from the back, don't pull the two pieces entirely apart. There is a flat orange wire that connects the two pieces that will be disconnected in the next step.
    • Snap apart the two internal clips located on the top corners of the device, and the two clips in the bottom corners.
    • Run the plastic opening tool around the edge of the entire device to pry apart the front of the phone from the back.
    • There is a small black plastic piece located at the bottom of the front assembly. Do not worry if the strip falls off; just simply snap it back on and proceed.
  8. Motorola Droid RAZR M Motherboard Replacement: 步骤 8 中的图像 1,3 Motorola Droid RAZR M Motherboard Replacement: 步骤 8 中的图像 2,3 Motorola Droid RAZR M Motherboard Replacement: 步骤 8 中的图像 3,3
    • Like a clamshell, slowly open the device from the top. Open the remainder of the device slowly while being mindful of the flat orange wire that connects the motherboard to the front assembly.
    • Undo the snap connection in the lower left corner by inserting the plastic opening tool under the end of the orange wire connected to the motherboard. Lift gently.
    • Once the snap connection is undone, pull apart the front assembly from the rest of the phone.
  9. Motorola Droid RAZR M Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,2 Motorola Droid RAZR M Motherboard Replacement, Motherboard: 步骤 9 中的图像 2,2
    • Remove the six 4mm T5 Torx screws located along the outer edge of the motherboard.
  10. Motorola Droid RAZR M Motherboard Replacement: 步骤 10 中的图像 1,2 Motorola Droid RAZR M Motherboard Replacement: 步骤 10 中的图像 2,2
    • Disconnect the snap connection in the lower left corner by prying underneath using the plastic opening tool.
  11. Motorola Droid RAZR M Motherboard Replacement: 步骤 11 中的图像 1,2 Motorola Droid RAZR M Motherboard Replacement: 步骤 11 中的图像 2,2
    • Disconnect the snap connection in the upper left corner by prying underneath using the plastic opening tool.
    • As you undo the snap connection, pull the rear facing camera off completely. It will slide out of its slot in the motherboard.
  12. Motorola Droid RAZR M Motherboard Replacement: 步骤 12 中的图像 1,2 Motorola Droid RAZR M Motherboard Replacement: 步骤 12 中的图像 2,2
    • Disconnect the snap connection in the upper right corner by prying underneath using the plastic opening tool.
  13. Motorola Droid RAZR M Motherboard Replacement: 步骤 13 中的图像 1,3 Motorola Droid RAZR M Motherboard Replacement: 步骤 13 中的图像 2,3 Motorola Droid RAZR M Motherboard Replacement: 步骤 13 中的图像 3,3
    • By inserting the plastic opening tool between the motherboard and rear casing, lift the bottom of the motherboard from the rear casing.
    • Use your fingers to gently pull the motherboard down and out of the rear casing.
结论
2等其他人完成本指南。
Ethan Look
于04/21/15注册
498 声望
创作了3篇指南
团队
Cal Poly, Team 15-1, Amido Spring 2015 Cal Poly, Team 15-1, Amido Spring 2015 的会员
CPSU-AMIDO-S15S15G1
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 20
总计 1,421
