跳转到主内容
Motorola Droid RAZR M Battery Replacement
你所需要的
  1. Motorola Droid RAZR M Battery Replacement, Front Assembly: 步骤 1 中的图像 1,3 Motorola Droid RAZR M Battery Replacement, Front Assembly: 步骤 1 中的图像 2,3 Motorola Droid RAZR M Battery Replacement, Front Assembly: 步骤 1 中的图像 3,3
    • Open the small latch on the left side of the device by lifting gently with your finger, exposing the SIM card and microSD card slots.
    • If either of these cards are present, remove them to prevent damaging them while taking apart the phone. Our device does not have either.
    • Close the latch once the two cards are removed.
  2. Motorola Droid RAZR M Battery Replacement: 步骤 2 中的图像 1,3 Motorola Droid RAZR M Battery Replacement: 步骤 2 中的图像 2,3 Motorola Droid RAZR M Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the six 4mm T3 Torx screws. There are 3 on each side of the device.
  3. Motorola Droid RAZR M Battery Replacement: 步骤 3 中的图像 1,3 Motorola Droid RAZR M Battery Replacement: 步骤 3 中的图像 2,3 Motorola Droid RAZR M Battery Replacement: 步骤 3 中的图像 3,3
    • Run the plastic opening tool under the bottom edge of the phone to detach the small plastic cover below the Verizon logo.
    • It will take some force to remove this piece. Work around the bottom corners to unlatch the two hooks holding the piece in place.
    • The small plastic hooks can break during removal. Be careful that you don't damage them, but it will take some force to get them undone.
    • Once the plastic cover is detached, pull the piece away with your fingers.
    Apply low heat in area as well, it makes the removal of this piece easier as it loosens the adhesive holding the cover.
    Anthony Merino - 回复
  4. Motorola Droid RAZR M Battery Replacement: 步骤 4 中的图像 1,2 Motorola Droid RAZR M Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the three T4 Torx screws. There are three at the bottom of the device.
  5. Motorola Droid RAZR M Battery Replacement: 步骤 5 中的图像 1,3 Motorola Droid RAZR M Battery Replacement: 步骤 5 中的图像 2,3 Motorola Droid RAZR M Battery Replacement: 步骤 5 中的图像 3,3
    • Using the plastic opening tool, peel away the silver Motorola plate at the top of the phone. There is a fair amount of adhesive underneath, so you may have to pry it from a few different angles.
    • As soon as you can get your finger underneath, pull away the silver plate.
  6. Motorola Droid RAZR M Battery Replacement: 步骤 6 中的图像 1,2 Motorola Droid RAZR M Battery Replacement: 步骤 6 中的图像 2,2
    • Remove the two 7mm T4 Torx screws at the top of the device.
  7. Motorola Droid RAZR M Battery Replacement: 步骤 7 中的图像 1,3 Motorola Droid RAZR M Battery Replacement: 步骤 7 中的图像 2,3 Motorola Droid RAZR M Battery Replacement: 步骤 7 中的图像 3,3
    • When you detach the front from the back, don't pull the two pieces entirely apart. There is a flat orange wire that connects the two pieces that will be disconnected in the next step.
    • Snap apart the two internal clips located on the top corners of the device, and the two clips in the bottom corners.
    • Run the plastic opening tool around the edge of the entire device to pry apart the front of the phone from the back.
    • There is a small black plastic piece located at the bottom of the front assembly. Do not worry if the strip falls off; just simply snap it back on and proceed.
  8. Motorola Droid RAZR M Battery Replacement: 步骤 8 中的图像 1,3 Motorola Droid RAZR M Battery Replacement: 步骤 8 中的图像 2,3 Motorola Droid RAZR M Battery Replacement: 步骤 8 中的图像 3,3
    • Like a clamshell, slowly open the device from the top. Open the remainder of the device slowly while being mindful of the flat orange wire that connects the motherboard to the front assembly.
    • Undo the snap connection in the lower left corner by inserting the plastic opening tool under the end of the orange wire connected to the motherboard. Lift gently.
    • Once the snap connection is undone, pull apart the front assembly from the rest of the phone.
  9. Motorola Droid RAZR M Battery Replacement, Motherboard: 步骤 9 中的图像 1,2 Motorola Droid RAZR M Battery Replacement, Motherboard: 步骤 9 中的图像 2,2
    • Remove the six 4mm T5 Torx screws located along the outer edge of the motherboard.
  10. Motorola Droid RAZR M Battery Replacement: 步骤 10 中的图像 1,2 Motorola Droid RAZR M Battery Replacement: 步骤 10 中的图像 2,2
    • Disconnect the snap connection in the lower left corner by prying underneath using the plastic opening tool.
  11. Motorola Droid RAZR M Battery Replacement: 步骤 11 中的图像 1,2 Motorola Droid RAZR M Battery Replacement: 步骤 11 中的图像 2,2
    • Disconnect the snap connection in the upper left corner by prying underneath using the plastic opening tool.
    • As you undo the snap connection, pull the rear facing camera off completely. It will slide out of its slot in the motherboard.
  12. Motorola Droid RAZR M Battery Replacement: 步骤 12 中的图像 1,2 Motorola Droid RAZR M Battery Replacement: 步骤 12 中的图像 2,2
    • Disconnect the snap connection in the upper right corner by prying underneath using the plastic opening tool.
  13. Motorola Droid RAZR M Battery Replacement: 步骤 13 中的图像 1,3 Motorola Droid RAZR M Battery Replacement: 步骤 13 中的图像 2,3 Motorola Droid RAZR M Battery Replacement: 步骤 13 中的图像 3,3
    • By inserting the plastic opening tool between the motherboard and rear casing, lift the bottom of the motherboard from the rear casing.
    • Use your fingers to gently pull the motherboard down and out of the rear casing.
  14. Motorola Droid RAZR M Battery Replacement, Battery: 步骤 14 中的图像 1,3 Motorola Droid RAZR M Battery Replacement, Battery: 步骤 14 中的图像 2,3 Motorola Droid RAZR M Battery Replacement, Battery: 步骤 14 中的图像 3,3
    • Peel back the plastic from the face of the battery.
  15. Motorola Droid RAZR M Battery Replacement: 步骤 15 中的图像 1,3 Motorola Droid RAZR M Battery Replacement: 步骤 15 中的图像 2,3 Motorola Droid RAZR M Battery Replacement: 步骤 15 中的图像 3,3
    • Pull up on the plastic to lift the battery out of the rear assembly casing.
    • There is adhesive securing the battery so you will need to apply a good amount of force.
    • Hold down the left edge of the rear assembly casing as you pull the battery out.
    It is kind of difficult because what happens if you break your phone by doing it.
    Sebastian ballensky - 回复
    It is true, the phone parts are delicate and the strip down and rebild requires care.... so do not take your phone apart unless it is already broken!
    Jim -
    Many thanks for this step by step guide. I used a tool set from Deyard and a bit of care and this invaluable guide and now I have a working phone again.
    Jim - 回复
结论
11等其他人完成本指南。
Thomas Fenner
于04/22/15注册
488 声望
撰写一个指南
团队
Cal Poly, Team 15-1, Amido Spring 2015 Cal Poly, Team 15-1, Amido Spring 2015 的会员
CPSU-AMIDO-S15S15G1
4 名成员
创作了14篇指南
6条评论
Thank you! This phone is really well-built, and a bear to disassemble. This guide had exactly what I needed to see.
Roy Thomasson - 回复
this was a rockin' guide!!! looked everywhere and here it is, and yes a bear but a cool one!
apriltanner1975 - 回复
Thank You! Hope this new battery works better than the old one!
autococker13 - 回复
Yeah it's kind of helpful.
where will i get the battery for the my own phone now
Timothy - 回复
where can i get the strong battery for my motorola XT907 please i need help
Timothy - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 8,434
