跳转到主内容
Motorola Droid RAZR M Battery Door Glass Lens Replacement
你所需要的
  1. Motorola Droid RAZR M Battery Door Glass Lens Replacement, Battery Door Glass Lens: 步骤 1 中的图像 1,1
    • Shattered!
  2. Motorola Droid RAZR M Battery Door Glass Lens Replacement: 步骤 2 中的图像 1,1
    • Glass won't just pop off. It is held by a very sticky tape. Carefully scraping the tape with the glass pieces off and vacuum the area after to prevent a clean surface.
    • Be aware of jumping tiny glass pieces during process. Protect your eyes and area around you. They can get stuck in skin too.
  3. Motorola Droid RAZR M Battery Door Glass Lens Replacement: 步骤 3 中的图像 1,1
    • To replace the part you first need to attach the sticky tape. It comes in the correct outlines. Take the inner parts out to keep those areas free (Camera, Flash, Loudspeaker and a hole).
    • Before you take the film off practice the attaching. You will have it hard to reposition after its attached. Same goes with the lens itself, practice before the tape film is off. Once you feel safe to go, peel the film off and go for it!
  4. Motorola Droid RAZR M Battery Door Glass Lens Replacement: 步骤 4 中的图像 1,1
    • Done :-)
终点
4等其他人完成本指南。
Alex R
于09/27/13注册
215 声望
撰写一个指南
3条评论
This is not a razr maxx !!!!
Fausto Lebron - 回复
This isn't a Razr Maxx. The back doesn't have glass on a razr maxx.
Alex Tucker - 回复
This is Droid razr m . not maxx
Qais Afridi - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 7,377
