跳转到主内容
Motorola Droid Pro SD Card/SIM Card PCB Board Replacement
你所需要的
  1. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the back cover using the thumb tab located on the bottom of the phone.
  2. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 步骤 2 中的图像 1,2 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 步骤 2 中的图像 2,2
    • Remove the battery using the thumb tab.
  3. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, SD Card/SIM Card PCB Board: 步骤 3 中的图像 1,2 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, SD Card/SIM Card PCB Board: 步骤 3 中的图像 2,2
    • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
  4. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 步骤 4 中的图像 1,3 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 步骤 4 中的图像 2,3 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 步骤 4 中的图像 3,3
    • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use extra force to unlock them.
    • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
  5. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 步骤 5 中的图像 1,2 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: 步骤 5 中的图像 2,2
    • Gently lift the SD & SIM card board (PCB) as shown.
    • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
结论
2等其他人完成本指南。
Kyle Shays
于10/28/15注册
836 声望
创作了4篇指南
团队
UMass Dartmouth, Team 1-6, Miles Fall 2015 UMass Dartmouth, Team 1-6, Miles Fall 2015 的会员
UMASSD-MILES-F15S1G6
3 名成员
创作了12篇指南
1指南评论
Does the replacement board have to be from the same phone or does any sim board work from any phone as long as it's 3g
lisa marie - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 435
