跳转到主内容
Motorola Droid Pro Keyboard Replacement
你所需要的
  1. Motorola Droid Pro Keyboard Replacement, SD Card/SIM Card PCB Board: 步骤 1 中的图像 1,2 Motorola Droid Pro Keyboard Replacement, SD Card/SIM Card PCB Board: 步骤 1 中的图像 2,2
    • Remove the back cover and battery by using the thumb tabs.
  2. Motorola Droid Pro Keyboard Replacement: 步骤 2 中的图像 1,1
    • Unscrew the 8 back panel screws using the T4 Torx screwdriver.
  3. Motorola Droid Pro Keyboard Replacement: 步骤 3 中的图像 1,1
    • Use a spudger to open the phone along the sides between the back panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use a little force to unlock them.
    • Go around on all sides then pull the back panel off.
  4. Motorola Droid Pro Keyboard Replacement: 步骤 4 中的图像 1,2 Motorola Droid Pro Keyboard Replacement: 步骤 4 中的图像 2,2
    • Gently lift the SD & SIM card board (PCB) as shown in the following pictures.
    • This will expose the ribbon cable attached to the board and another ribbon cable for the mother board. Remove them both using the spudger.
    • Once the small one is removed the small board can be pulled off.
  5. Motorola Droid Pro Keyboard Replacement, Screen: 步骤 5 中的图像 1,1
    • Unscrew the 6 screws using the T5 Torx screwdriver.
  6. Motorola Droid Pro Keyboard Replacement: 步骤 6 中的图像 1,1
    • Unlock the ribbon cable and then you can pull the screen out.
    • When replacing screen make sure you lock the ribbon cable back in place.
  7. Motorola Droid Pro Keyboard Replacement, Keyboard: 步骤 7 中的图像 1,1
    • Pop out key board using a spudger on the marked points.
    • The keyboard is locked in place, but can pop in and out. You may need to use a little force to get it out.
    • Once out you can pop the new keyboard in the opposite way you took it out.
结论
Peter Cakounes
于10/21/14注册
19 声望
创作了4篇指南
团队
UMass Dartmouth, Team 5-8, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-8, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S5G8
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 166
