跳转到主内容
Motorola Droid Pro Camera Replacement
你所需要的
  1. Motorola Droid Pro Camera Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the back cover using the thumb tab located on the bottom of the phone.
  2. Motorola Droid Pro Camera Replacement: 步骤 2 中的图像 1,2 Motorola Droid Pro Camera Replacement: 步骤 2 中的图像 2,2
    • Remove the battery using the thumb tab.
  3. Motorola Droid Pro Camera Replacement, SD Card/SIM Card PCB Board: 步骤 3 中的图像 1,2 Motorola Droid Pro Camera Replacement, SD Card/SIM Card PCB Board: 步骤 3 中的图像 2,2
    • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
  4. Motorola Droid Pro Camera Replacement: 步骤 4 中的图像 1,3 Motorola Droid Pro Camera Replacement: 步骤 4 中的图像 2,3 Motorola Droid Pro Camera Replacement: 步骤 4 中的图像 3,3
    • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use extra force to unlock them.
    • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
  5. Motorola Droid Pro Camera Replacement: 步骤 5 中的图像 1,2 Motorola Droid Pro Camera Replacement: 步骤 5 中的图像 2,2
    • Gently lift the SD & SIM card board (PCB) as shown.
    • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
  6. Motorola Droid Pro Camera Replacement, Motherboard: 步骤 6 中的图像 1,2 Motorola Droid Pro Camera Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Use your plastic opening tool to disconnect the motherboard/keyboard ribbon cable.
    • There are small tabs on the side of the connectors to wedge your tool under.
  7. Motorola Droid Pro Camera Replacement: 步骤 7 中的图像 1,2 Motorola Droid Pro Camera Replacement: 步骤 7 中的图像 2,2
    • Use your plastic opening tool to disconnect the two ribbon cables at the top of the phone.
  8. Motorola Droid Pro Camera Replacement: 步骤 8 中的图像 1,2 Motorola Droid Pro Camera Replacement: 步骤 8 中的图像 2,2
    • Disconnect the 2nd keyboard connector from the motherboard and remove it from its side holders.
    • This cable is fragile so be careful when disconnecting and moving it around.
  9. Motorola Droid Pro Camera Replacement: 步骤 9 中的图像 1,1
    • Use a T5 Torx Screwdriver to unscrew the 2mm screw.
  10. Motorola Droid Pro Camera Replacement: 步骤 10 中的图像 1,3 Motorola Droid Pro Camera Replacement: 步骤 10 中的图像 2,3 Motorola Droid Pro Camera Replacement: 步骤 10 中的图像 3,3
    • Remove the camera's rubber seal by pulling it off. It is not connected to anything.
  11. Motorola Droid Pro Camera Replacement: 步骤 11 中的图像 1,2 Motorola Droid Pro Camera Replacement: 步骤 11 中的图像 2,2
    • To remove the motherboard, pull it to the side. The camera that is connected to the motherboard does not pull straight up and out from its holder.
  12. Motorola Droid Pro Camera Replacement, Camera: 步骤 12 中的图像 1,3 Motorola Droid Pro Camera Replacement, Camera: 步骤 12 中的图像 2,3 Motorola Droid Pro Camera Replacement, Camera: 步骤 12 中的图像 3,3
    • The camera is located on the back side of PCB board.
    • Flip the board over and you will see that the camera is connected by a ribbon cable.
    • Unlock the cable by using a plastic remover tool then pull the camera out.
    • Insert the new camera and re lock the ribbon cable.
    • Do not use excessive force and make sure the cameras ribbon cable gets properly re seated.
结论
2等其他人完成本指南。
团队
UMass Dartmouth, Team 1-6, Miles Fall 2015 UMass Dartmouth, Team 1-6, Miles Fall 2015 的会员
UMASSD-MILES-F15S1G6
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 140
