跳转到主内容
Motorola Droid MAXX 2 Earpiece Speaker Replacement
你所需要的
  1. Motorola Droid MAXX 2 Earpiece Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Motorola Droid MAXX 2 Earpiece Speaker Replacement: 步骤 2 中的图像 1,1
    • Pull the sim card tray up out of the phone
  3. Motorola Droid MAXX 2 Earpiece Speaker Replacement: 步骤 3 中的图像 1,2 Motorola Droid MAXX 2 Earpiece Speaker Replacement: 步骤 3 中的图像 2,2
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Motorola Droid MAXX 2 Earpiece Speaker Replacement: 步骤 4 中的图像 1,1
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • These may be T3 screws. If you are having trouble unscrewing these, stop and try a T3 bit.
  5. Motorola Droid MAXX 2 Earpiece Speaker Replacement: 步骤 5 中的图像 1,1
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  6. Motorola Droid MAXX 2 Earpiece Speaker Replacement: 步骤 6 中的图像 1,3 Motorola Droid MAXX 2 Earpiece Speaker Replacement: 步骤 6 中的图像 2,3 Motorola Droid MAXX 2 Earpiece Speaker Replacement: 步骤 6 中的图像 3,3
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  7. Motorola Droid MAXX 2 Earpiece Speaker Replacement: 步骤 7 中的图像 1,1
    • Remove the disconnected battery from the phone.
  8. Motorola Droid MAXX 2 Earpiece Speaker Replacement, Earpiece Speaker: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Grab the speaker with the tweezers and gently pull up on the speaker.
    • The speaker is held in place around the edges with adhesive, so there will be some resistance when you try to remove the speaker from the phone.
结论
Burke Seggerman
于03/18/18注册
704 声望
创作了5篇指南
团队
Baylor, Team S3-G4, Williams Spring 2018 Baylor, Team S3-G4, Williams Spring 2018 的会员
BU-WILLIAMS-S18S3G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 9
总计 666
