跳转到主内容
Motorola Droid MAXX 2 Button Assembly Replacement
你所需要的
  1. Motorola Droid MAXX 2 Button Assembly Replacement, Battery: 步骤 1 中的图像 1,1
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Motorola Droid MAXX 2 Button Assembly Replacement: 步骤 2 中的图像 1,1
    • Pull the sim card tray up out of the phone
  3. Motorola Droid MAXX 2 Button Assembly Replacement: 步骤 3 中的图像 1,2 Motorola Droid MAXX 2 Button Assembly Replacement: 步骤 3 中的图像 2,2
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Motorola Droid MAXX 2 Button Assembly Replacement: 步骤 4 中的图像 1,1
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • These may be T3 screws. If you are having trouble unscrewing these, stop and try a T3 bit.
  5. Motorola Droid MAXX 2 Button Assembly Replacement: 步骤 5 中的图像 1,1
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  6. Motorola Droid MAXX 2 Button Assembly Replacement: 步骤 6 中的图像 1,3 Motorola Droid MAXX 2 Button Assembly Replacement: 步骤 6 中的图像 2,3 Motorola Droid MAXX 2 Button Assembly Replacement: 步骤 6 中的图像 3,3
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  7. Motorola Droid MAXX 2 Button Assembly Replacement: 步骤 7 中的图像 1,1
    • Remove the disconnected battery from the phone.
  8. Motorola Droid MAXX 2 Button Assembly Replacement, Button Assembly: 步骤 8 中的图像 1,2 Motorola Droid MAXX 2 Button Assembly Replacement, Button Assembly: 步骤 8 中的图像 2,2
    • Peel back the orange adhesive covering the ZIF connector.
  9. Motorola Droid MAXX 2 Button Assembly Replacement: 步骤 9 中的图像 1,2 Motorola Droid MAXX 2 Button Assembly Replacement: 步骤 9 中的图像 2,2
    • Lift the black tab on the ZIF connector up.
    • Pull the ribbon cable out of the ZIF connector.
  10. Motorola Droid MAXX 2 Button Assembly Replacement: 步骤 10 中的图像 1,3 Motorola Droid MAXX 2 Button Assembly Replacement: 步骤 10 中的图像 2,3 Motorola Droid MAXX 2 Button Assembly Replacement: 步骤 10 中的图像 3,3
    • Use the plastic spudger to loosen the metal prongs that hold the button assembly onto the phone.
  11. Motorola Droid MAXX 2 Button Assembly Replacement: 步骤 11 中的图像 1,1
    • Pull the button assembly up and out of the phone.
结论
Burke Seggerman
于03/18/18注册
704 声望
创作了5篇指南
团队
Baylor, Team S3-G4, Williams Spring 2018 Baylor, Team S3-G4, Williams Spring 2018 的会员
BU-WILLIAMS-S18S3G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 524
