跳转到主内容
Motorola Droid Bionic LCD Replacement
你所需要的
  1. Motorola Droid Bionic LCD Replacement, LCD: 步骤 1 中的图像 1,1
    • Remove the back battery cover.
  2. Motorola Droid Bionic LCD Replacement: 步骤 2 中的图像 1,1
    • Remove the battery
  3. Motorola Droid Bionic LCD Replacement: 步骤 3 中的图像 1,2 Motorola Droid Bionic LCD Replacement: 步骤 3 中的图像 2,2
    • Remove the 11 T4 Torx Screws
    • Next, remove the information sticker.
  4. Motorola Droid Bionic LCD Replacement: 步骤 4 中的图像 1,2 Motorola Droid Bionic LCD Replacement: 步骤 4 中的图像 2,2
    • Using a plastic removal tool, work around the edges of the back housing.
    • Lift off the back housing.
  5. Motorola Droid Bionic LCD Replacement: 步骤 5 中的图像 1,3 Motorola Droid Bionic LCD Replacement: 步骤 5 中的图像 2,3 Motorola Droid Bionic LCD Replacement: 步骤 5 中的图像 3,3
    • Remove the two silver T4 screws securing the SIM tray.
    • Carefully lift the SIM tray to disconnect it from the board.
    • Carefully remove the plastic spacer beneath by lifting gently in the center with a plastic removal tool.
    • Then, using a plastic removal tool, disconnect the speaker & front facing camera assembly from the board. The speaker is attached with adhesive, so be careful not to rip the flex cable.
  6. Motorola Droid Bionic LCD Replacement: 步骤 6 中的图像 1,1
    • Disconnect the 2 digitizer connectors using a plastic removal tool.
    • Then disconnect the LCD connector
  7. Motorola Droid Bionic LCD Replacement: 步骤 7 中的图像 1,2 Motorola Droid Bionic LCD Replacement: 步骤 7 中的图像 2,2
    • The board is now free from all connections. Carefully lift from the top and remove the board.
  8. Motorola Droid Bionic LCD Replacement: 步骤 8 中的图像 1,2 Motorola Droid Bionic LCD Replacement: 步骤 8 中的图像 2,2
    • Carefully peel the two flex cables from the back housing of the LCD. Be exceptionally careful during this process, as those flex cables can be easily ripped.
    • With the flex cables out of the way, you can now use a plastic opening tool to carefully pry the old LCD loose and out of the display.
    • If you're installing a new LCD, simply add it now and follow these instructions in reverse to complete the installation.
结论
4等其他人完成本指南。
Taylor
于08/30/12注册
244 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 14
总计 1,780
