简介
The rear bezel holds most of the phone together. The rear bezel needs to be removed to allow you to have access to the internal parts of the phone besides the battery.
You will need to remove several torx head screws. Make sure to use the correct type.
你所需要的
Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
Slide the cover down to remove.
在这个步骤中使用的工具:T5 Torx Screwdriver$5.49
Use the T5 Torx Screwdriver to remove both 2.5 mm screws from the battery cable.
Use the Spudger to unstick the battery.
Using the blue plastic opening tool, pry off the thin plastic camera cover.
Remove the four screws, indicated by the red circles, with the screwdriver and T5 Torx bit.
Insert the spudger between the rear bezel and the main housing.
Slide the spudger around all sides of the phone to separate the bezel from the housing.
Pry the bezel free.
