跳转到主内容
Motorola Droid 4 Motherboard Replacement
你所需要的
  1. Motorola Droid 4 Motherboard Replacement, Removing Rear Panel: 步骤 1 中的图像 1,3 Motorola Droid 4 Motherboard Replacement, Removing Rear Panel: 步骤 1 中的图像 2,3 Motorola Droid 4 Motherboard Replacement, Removing Rear Panel: 步骤 1 中的图像 3,3
    • Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
    • Slide the cover down to remove.
  2. Motorola Droid 4 Motherboard Replacement, Battery: 步骤 2 中的图像 1,1
    • Remove the sticker on the rear compartment to reveal the battery.
    • Hold the battery with your thumb while removing the sticker or you might end up ripping the battery out of the phone, damaging the flex cable.
  3. Motorola Droid 4 Motherboard Replacement: 步骤 3 中的图像 1,2 Motorola Droid 4 Motherboard Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    T5 Torx Screwdriver
    $5.49
    购买
    • Use the T5 Torx Screwdriver to remove both 2.5 mm screws from the battery cable.
    • Use the Spudger to unstick the battery.
    • It's difficult to remove the battery without a pry tool like the spudger because of the strong adhesive. If you try removing it with just your fingers, the battery may bend.
  4. Motorola Droid 4 Motherboard Replacement, Camera Cover Removal: 步骤 4 中的图像 1,3 Motorola Droid 4 Motherboard Replacement, Camera Cover Removal: 步骤 4 中的图像 2,3 Motorola Droid 4 Motherboard Replacement, Camera Cover Removal: 步骤 4 中的图像 3,3
    • Using the blue plastic opening tool, pry off the thin plastic camera cover.
    • The plastic cover is fragile, so proceed carefully.
  5. Motorola Droid 4 Motherboard Replacement, Remove Screws: 步骤 5 中的图像 1,2 Motorola Droid 4 Motherboard Replacement, Remove Screws: 步骤 5 中的图像 2,2
    • Remove the four screws, indicated by the red circles, with the screwdriver and T5 Torx bit.
    • The screws are philips 2.5mm. One screw is a different color (silver) from the others (black).
  6. Motorola Droid 4 Motherboard Replacement, Remove Bezel: 步骤 6 中的图像 1,3 Motorola Droid 4 Motherboard Replacement, Remove Bezel: 步骤 6 中的图像 2,3 Motorola Droid 4 Motherboard Replacement, Remove Bezel: 步骤 6 中的图像 3,3
    • Insert the spudger between the rear bezel and the main housing.
    • The bezel is fragile, so proceed carefully.
    • Slide the spudger around all sides of the phone to separate the bezel from the housing.
    • Pry the bezel free.
    • Be careful of the adhesive that holds the bezel to the main housing. Prying too hard may damage your phone.
  7. Motorola Droid 4 Motherboard Replacement, Removing screws: 步骤 7 中的图像 1,2 Motorola Droid 4 Motherboard Replacement, Removing screws: 步骤 7 中的图像 2,2
    • Remove the 12 screws holding the housing in place using a T5 Torx screwdriver.
    • Follow the red circles, indicated in the picture, to locate the screws.
    • The 12 screws are (silver) philips 2.5mm
  8. Motorola Droid 4 Motherboard Replacement, Separation of the Housing from the Motherboard: 步骤 8 中的图像 1,3 Motorola Droid 4 Motherboard Replacement, Separation of the Housing from the Motherboard: 步骤 8 中的图像 2,3 Motorola Droid 4 Motherboard Replacement, Separation of the Housing from the Motherboard: 步骤 8 中的图像 3,3
    • Separate the housing from the motherboard.
    • Be careful while separating the housing. The power and volume buttons are easily separated from the housing and can be damaged.
  9. Motorola Droid 4 Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,2 Motorola Droid 4 Motherboard Replacement, Motherboard: 步骤 9 中的图像 2,2
    • The Motherboard is the brain of the phone, handle with care.
    • Using the spudger, separate the motherboard from the keyboard frame.
    • Tilt the motherboard upward from the side of the charger connection as shown in the picture.
  10. Motorola Droid 4 Motherboard Replacement, Disconnecting the Motherboard: 步骤 10 中的图像 1,2 Motorola Droid 4 Motherboard Replacement, Disconnecting the Motherboard: 步骤 10 中的图像 2,2
    • Using the spudger, gently disconnect the two motherboard connections.
    • Once the motherboard is separated from the phone place it in a safe place.
结论
另外一个人完成了本指南。
Javier
于09/29/14注册
530 声望
创作了4篇指南
团队
USF Tampa, Team 5-1, Mcgee Fall 2014 USF Tampa, Team 5-1, Mcgee Fall 2014 的会员
USFT-MCGEE-F14S5G1
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 16
总计 956
