本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to replace your Droid 2's camera assembly.
你所需要的
Slide the battery cover toward the bottom edge of the phone.
Remove the battery cover from the rear of the phone.
Using the tip of a spudger, peel up one corner of the silver ribbon below the battery compartment.
Peel the ribbon off the phone.
Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board.
De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
Disconnect the camera connector from its socket by prying it straight up with a spudger.
Remove the camera assembly from the motherboard.
另外一个人完成了本指南。
