跳转到主内容
Motorola Defy XT Screen Replacement
你所需要的
  1. Motorola Defy XT Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
  2. Motorola Defy XT Screen Replacement: 步骤 2 中的图像 1,1
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone.
    • Remove the back cover and set it aside.
  3. Motorola Defy XT Screen Replacement: 步骤 3 中的图像 1,1
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
  4. Motorola Defy XT Screen Replacement, SD Card: 步骤 4 中的图像 1,1
    • Open the plastic cover with your finger, exposing the SD card.
    • Use the opening tool to grab the edge of the SD card and pull it straight out.
  5. Motorola Defy XT Screen Replacement, Screen: 步骤 5 中的图像 1,2 Motorola Defy XT Screen Replacement, Screen: 步骤 5 中的图像 2,2
    • Use the Torx T4 screwdriver to remove the six 3 mm screws from the back case.
  6. Motorola Defy XT Screen Replacement: 步骤 6 中的图像 1,1
    • Use the plastic opening tool to pop the volume buttons off from the side of the phone.
  7. Motorola Defy XT Screen Replacement: 步骤 7 中的图像 1,1
    • Wedge the plastic opening tool between the plastic layer and the shiny front cover.
  8. Motorola Defy XT Screen Replacement: 步骤 8 中的图像 1,1
    • Slide the plastic opening tool along the edge, wedging the the two pieces apart.
    • Potential for device damage: Do not completely separate the two pieces; there are still internal components that need to be disconnected.
  9. Motorola Defy XT Screen Replacement: 步骤 9 中的图像 1,2 Motorola Defy XT Screen Replacement: 步骤 9 中的图像 2,2
    • Slide the screen out and disconnect the ribbon cable connecting the display to the motherboard by pulling straight outward.
    • Potential for device damage: Be careful when sliding out the screen because the front case and the motherboard are still connected by two other ribbon cables.
  10. Motorola Defy XT Screen Replacement: 步骤 10 中的图像 1,2 Motorola Defy XT Screen Replacement: 步骤 10 中的图像 2,2
    • Set the old screen aside and replace it with your new screen.
结论
2等其他人完成本指南。
Oscar Camacho
于04/19/13注册
89 声望
撰写一个指南
团队
Cal Poly, Team 2-22, Maness Spring 2013 Cal Poly, Team 2-22, Maness Spring 2013 的会员
CPSU-MANESS-S13S2G22
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 3,130
