跳转到主内容
Motorola Defy XT SD Card Replacement
你所需要的
  1. Motorola Defy XT SD Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
  2. Motorola Defy XT SD Card Replacement: 步骤 2 中的图像 1,1
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone.
    • Remove the back cover and set it aside.
  3. Motorola Defy XT SD Card Replacement: 步骤 3 中的图像 1,1
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
  4. Motorola Defy XT SD Card Replacement, SD Card: 步骤 4 中的图像 1,1
    • Open the plastic cover with your finger, exposing the SD card.
    • Use the opening tool to grab the edge of the SD card and pull it straight out.
结论
2等其他人完成本指南。
Dorian Capps
于04/19/13注册
64 声望
创作了2篇指南
团队
Cal Poly, Team 2-22, Maness Spring 2013 Cal Poly, Team 2-22, Maness Spring 2013 的会员
CPSU-MANESS-S13S2G22
3 名成员
创作了8篇指南
2指南评论
I have replaced the SD card --32 GB---with smaller GB card-- and still my XT phone does not allow movement of APP to this card or saving photo files.
Any other suggestions to get phone to recognize the new card. Cant drag an APP (calculator, eg) to that memory card.
Must I format or seat the card ? or get a different brand ScanDisk 32?
Memorex 8 with Settings reads 7.2 GB total space on this smaller new card.
Gardner
Gardner Neely - 回复
thanks for any guidance on memory card problems Mounting/activating so that I can add files or APPS to that SD card on my Motorola Defy XT 2012 mobile phone.
Gardner Neely -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 2,410
