当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Carefully separate the bottom piece from the top plastic piece.
Disconnect the ribbon cable connecting the display to the logic board by firmly pulling the cable straight outward.
The screen can now be removed.
Separate the logic board and the display cover from the back cover and orient the logic board so the camera faces toward you.
Disconnect the back cover by wedging the plastic opening tool in between the motherboard and the connector and prying outward.
Flip the logic board and display cover over so the camera faces away from you.
Bend the two halves of the device away from you to pry the final ribbon connector off the logic board.
The ribbon connector is bonded to the logic board with adhesive, simply pull it to break the glue bond.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
